~-==KYOSHO MINI Z racer==-~
Any of you race these thing?
Any tuning advice to give or know of a forum that is helpful?
What are the essential upgrades to this car?
These cars are popular but seems like not many people talk about them...
Regional Moderator
i bought one from HK a while back but havent used it as of late. first things to go are the bushings, stock tires, and motor. bearings are definitely the way to go, and a good setup for tires are the 40 shore for reasonable balance and 30 shore if you want insane traction. you should retune the suspension when you go to for softer tires. traction roll is common without tuning. the stock H bar is a bit soft so you may want to do away with that as well. not a lot of people run the stock diff (or if they do, they use very heavy grease). you may want to opt for a ball diff.
Is the rear damper necessary? From my observations it looks like the h-plate does the majority of the work before the damper even starts to compress.
mini Z settings
advised to change the H plate to graphite, ball diff, rear shocks, X-speed motor, the rest could remain as stock and the car would perform
Originally posted by EPracing
mini Z settings
mini Z settings
by the way: anyone ever heard of that mini z turbo chip? what the heck is that thing? does it really make the car go faster?
Originally posted by stoopidbstrd
i heard the x speed motor is pretty crappy. there are a whole punch of motors that are probably better. go to china or have someone go there for you to find some mini z stuff. there's hella there.
The MiniZ has only one circuit board which contains both the control (like the reciever in a larger car) and the motor driving circuitry (like the ESC). As such, you cannot use a high ouput motor in the MiniZ without literally frying the board. The turbo chip uses the original power output of the MiniZ's board as a signal source and draws power seperately to drive the motor.
Well, this is what I know anyway, hope it helped.
Cheers
Originally posted by NightKidZ
The "turbo chip" is a piggy back power amplifer. Let me explain.
Cheers
Cheers
Regional Moderator
im running 2 stacks of 7 fets and can run what ever motor i want with no trouble
