Old 01-04-2007, 08:03 AM   #1
Default How to match cells?
I've just bought 18 IB3800 cells unmatched to make into 3 packs. Is there a quick way of matching them using just a charger, smart tray and multimeter?
rbecking is offline   Reply With Quote
Old 01-04-2007, 09:48 AM   #2
Iceracer's Avatar
Matching is done under heavier loads than a smart tray provides. You need a way to measure average voltage and run time at 30-35 amps discharge rate.
Iceracer is offline   Reply With Quote
Old 01-04-2007, 10:22 AM   #3
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
you need to make a battery holder of some kind that can discharge a single cell at 35 amps. You also need a voltmeter and take a voltage reading about every 30 seconds or so while keeping track of how long it takes the pack to discharge to .9 volts. You're best bet is to just buy matched packs next time, or if you want to invest the money, pick up a turbo matcher.
Associated B44.3/Viper/RevTech
Associated B5M/Hobbywing/Orion
S & N's Trackside
AssocRacer is offline   Reply With Quote
Old 01-04-2007, 06:33 PM   #4
The quick way, using the items you have, is to charge them all until they peak and then measure the time it takes to discharge to certain voltage, usually 0.9volts.
Better way is to buy or borrow TurboMatcher.
Be warned, the quick way is not a good way to match cells. The good batterymatching companies use special temperature controlled rooms and huge batches of cells when matching.
andsetinn is offline   Reply With Quote
How to match cells with CTX-d2 bigbutstupid Radio and Electronics 0 02-26-2008 02:50 AM
Much More ForceMax 4300 Zap/Match Cells need4speed Electric On-Road 0 10-03-2006 02:43 AM
PRO-MATCH IB3800 4-CELLS Almost New Tornado_Racing R/C Items: For Sale/Trade 5 07-23-2006 06:07 AM
Match Dates On Cells Drew_Cat Electric On-Road 8 04-28-2005 04:33 PM
Who can Zap and Match Cells? tunerjetta29 Electric On-Road 0 10-27-2004 12:03 AM
SEO by vBSEO 3.5.0
