Alex Racing Barracuda R2 & R3
Nobody really don't know..Maybe if so that he's in the navy then he could be sea duty for along time my .02 cent
Originally posted by OVA
GTO2 You can't put CG and ARM together There isn't no such thing CG arm
So what's the main benefit of having 4 spacers at the rear?
more rear traction, higher roll center ? thanks.
Regional Moderator
If Dave is on duty still over, wherever he may be, the Navy could have him real busy or just have problems at home...hope things are going alright wherever he is. I would think he would let us know...
Regional Moderator
Hard to say...
xenon front c-hubs
Whats up with these uprights?Why were they desigened to limit droop the way they do?Is there a special arm so maximum droop can be achieved and be set by the droop set screw instead of the c-hub thickness limiting the travel?What are others running?Stock c hub?I know linger does for this reason.Anyone else have a solution?
Originally posted by raving-monkey
thanks for that steve.
you were the first place i looked at the pro4 and cuda.
just wondering, how long does it usually tke to get a kit/parts from the US to UK (and roughly how much for a kit )
thanks
matt
thanks
matt
Usually for a package to reach UK it only takes 4-5 days (sometimes less) I had customer receive packages in 3 days sometimes. Shipping will depend on the weight of the package, and for a car kit is usually around $45 USD by USPS EMS
Steve Wang
Hi Guys,
Dave Berger as far as I know is taking a break from R/C. He gave it a 110% last year for us in developing the R2 chassis and setup, so I understand if he was burn out from that.
JDM on the otherhand sorta just disappeared. I did hear some stories about packages from him never arriving though...and maybe the navy does have him too busy at work right now to even be on here.
Steve Wang
Steve Wang
Hi Steve,
Any news about the locked diff for the Barracuda? Please advise how much they weight as well if possible.
Best regards,
Mark
Best regards,
Mark
I've had a chance to try the spool, these things are the real deal. A fulls day racing and there are no signs of wear. I suggest though that everyone re-lube and replace the CVD pins... this part will wear out before anything else does. Also lube the dog bone pin that sits through the spool just a little. The one that I have is about 2 grams heavier than the one-way but mine was just a prototype.
GTO2
Yes higher roll center and maybe alittle more rear traction..
In old school I use to added spacer in the rear to lower the chassis and lower the CG too...
But now day I wouldn't add four in the rear today r/c TC..
Hi everyone,
If I attach the camber link to the top location on the rear hub, what will be the general feeling? Will I increase or decrease rear traction?
Regards,
Mark
Regards,
Mark
that should be lowering the roll center. It will roll less in cornering. On the other hand, too much roll will make the car feel twitchy.
Originally posted by dhiracing.com
Hi everyone,
Regards,
Mark
Hi everyone,
Regards,
Mark
I run mine on the top all around. I also run indoors on carpet usually with an 8 turn. I definatly felt an improvement going with the upper holes.
i delamenated the fron end of my chassis last night right at the front i think it may have been sticking down below the bumper a tad. I really should have sanded and sealed the edges of the chassis as instructed well now i know.Just a warning for anyone out there who hasnt done it yet, anyway i was needing a xenon stage 2 anyway got a red one on order dunno how long itl be till i get it tho so be running with a shady chassisfor now.
