Alex Racing Barracuda R2 & R3
#9496
Hi Joe,
Getting upset already? Adrian with the FT TC3 (prepared by yourself) is as good as Karl, especially with a stock motor.
I do not want to add more bla bla to all this. There are no excuses. Keep it up
#9497
Is anyone using the titanium axles on the R2 & R3? How are they holding up?
#9498
Do you guys use the middle span suspension arms for carpet racing only or outdoors as well?
#9501
R3 has so much potential.. i just need to unlock it!
#9502
Thanks for the info ...
Are you all still using the front one-way or changed to a normal front diff?
#9504
Regional Moderator
I use the mid span inside and outside and for the Ti axles they are super smooth and have held up very well.
#9505
Regional Moderator
Originally posted by Hebiki
drivetrain is a lot smoother with the TI Axles.. frees them up a bit more. im also using the midspan arms.. got more steering last night thanks to randman.
what did brother randy do for you bro on the steering ?
#9506
its still not very twitchy... i want it to be "nervous, shaking in the corner a homeless crack addict going cold turkey" kind of twitchy.
anyways..we laid the shocks down in the front, dumped the sway bars all around and shortened the camber links to the outer most holes.. and im using the mid span arms now.
final thing id like to do is to put 5.75 springs in the front and put in the hpi #2 pistons.
pistons might make the biggest difference since im running 40wt oil. steve recommended 20wt with the stock R3 pistons
now i just gotta find some HPI #2 pistons to buy
#9509
its more like what DIDNT he do?
there are 2 different sizes on the parts tree one is about 1mm the other 1,1mm
what size are the hpi pistons?
did anyone try rayspeed pistons?
#9510
R/C Tech Elite Member
btw.. THANKS FOR YOUR HELP RANDMAN.
did you notice in my second qualifying i held second for a few laps there before i got outmotored and my brain glitched
If you want a nervous car, go to Steve's shop and pick up some 1.4x5 & 1.4x5.25 springs, throw em on the car with some 1.2x3 hole pistons with 40wt oil, and tell me what you think
