Alex Racing Barracuda R2 & R3
#9226
Thanks for all your help guys! I really appreciate it. I read about people using this Speedway Pal system and various other items for the Barracuda but have no idea what they do? I guess I will have to keep looking through this thread!
Joe
Joe
#9227
Regional Moderator
Joe
Joe
the speedway pal system was used on the R2 in order to keep from stripping the spur gear with mod racing . with the R3
there is no worries they have corrected that problem with the new motor mount! the chassis and upper deck is 2.5 mm . to run the foams you can pick up a set of xenon hubs or speedwaypal
and your ready to mount the foams with out rubbing issues.
If you have more questions please ask
#9228
Xenon hubs aren't a good idea for 28mm foams, the rears won't work them them. I get the plastic on the ball link rubbing when using 26mm wheels. The fronts are fine with 26mm wheels but I'm not sure how they'd cope with 28mm foams, probably best sticking to Speedway PAL items all round so you have the drop links front and rear too.
#9231
R/C Tech Elite Member
Originally posted by Mr. MR4
Managed to get some pics of my car finally
Ko Racer - Recognise this car??
How can I change the rear toe in of the R2??
KARL
KARL
#9232
Originally posted by OVA
Hi Herminator
Speaking of using drop link ,If you use the drop link hop up and it will higher your roll center and which meant your car will react quicker .... Most racer set or use low roll center for carpet with foam tires .
Hi Herminator
I need to do some reading up again on roll centers, I'll get each setup option figured out one of these days
#9233
Regional Moderator
and there is no rubbing
#9234
Regional Moderator
picture of the rear looks close but no rub
#9235
Regional Moderator
KARL
KARL
looking good and the rear toe in looks wacked out i guess the photo angle but as randman said use the gold off centerd ball mounts
#9236
my 26mm wheels seem to give the same clearance on the rear as the photo you posted shows. I'm using the big screw down link so thats where the rubbing comes from.
The wheels I'm using are quite old now, I'm pretty sure they have no offset, they are quite wide even for 26mm though.
Another mystery KO
#9237
Regional Moderator
maybe those wheels have a built in 2mm offset?
Another mystery KO
Another mystery KO
lol Another mystery you say WHERE IS DAVE BRISTOL ???????????? thats a mystery
#9238
#9239
Regional Moderator
well my R3 is ready for action in the morning
