Alex Racing Barracuda R2 & R3
#4292
So you like the Torx screws then I would use them too if replacements were easy to come by but I also like the Titanium racing 2mm hex head screws, they have a nice sized head that stops the screws from sitting slightly proud of the bottom of the chassis like the kit ones do and even Tamiya titanium ones a little bit. Hopefully I'll have a better quality 2mm driver soon too thanks to Dave, but no thanks to Dave's postie
chkboy5- Talk to Steve at Speedtech if you want to get the conversion, but Randman is right, don't go spending a fortune on hop ups until you've got the car running. Half the reason I will be changing is just because I've given my kit chassis a battering over the outdoor season, the easy access spur is a nice bonus though
#4293
Originally posted by rocketron
unfortunately not - still see them stripping at socal. but as one of them says "there like brushes one run and you change it"
I would be fed up with changing brushes every run too
#4294
Originally posted by Herminator
I would be might pissed if I had to change diff gears once a run
this is exactly why i run the BL System now
at least the gears are easy to change and cost the same as brushes - hahaha
#4295
Regional Moderator
#4296
Originally posted by Ko Racer
yeah that is why this is the CUDA thread and not EVO III
With improvements on the stock drive train and with a less than perfect build, you could end up changing spurs on the Barracuda every run though
Good job we have us here to tell people how to build it properly
Although one person is missing, where are you RBF?
#4297
so how do we keep it from strippin?
#4299
#4300
i wonder if i should just get a brushless system instead of buyin esc n motor
#4301
Regional Moderator
checkboy, I have no problems with my box stock R2. It's an awesome car w/o the upgrades. I will get torx screws and MAYBE the pal upgrade but I run box stock at my track and it is fast and smooth. It took a lot to convince me that I wouldn't find something smoother than my yoke but I was wrong. Run the car and tune it first before you go crazy buying this and that. Even Steve and Dave told me that. They weren't lying. Like i said, I might upgrade down the road but I wanna get a couple of races on the carpet 1st.
#4302
R/C Tech Elite Member
Originally posted by stonedgti
Randman :
I'm thinking about buying either a Barracuda or EVO III SE. Now I know you have both. So which one do you like better?
Both cars have their own problems.
Barracuda:
Need Pal System so the spur dosen't strip. Cost me more $$.
EVO III:
The One-Way strip problem...
Randman :
Barracuda:
EVO III:
Check your PM
#4304
