Alex Racing Barracuda R2 & R3
#4126
Originally posted by Ko Racer
lol i was wondering if you had one or not
#4127
it is on my sig
#4128
Regional Moderator
Originally posted by cHckbOY5
yea i got a blue one from speedtech like a week or so ago... havent built it yet though, still gotta buy tools hehe
whats up with that
#4129
my first car... well not really, i had a tc3 but i just used the tools that came with the kit. but this time i want to get better tools n stuff, gettin more serious
#4131
Regional Moderator
#4132
i kno doood, i was looking at the instruction manual... n its pretty confussin, the whole thing >.<
#4133
Regional Moderator
Originally posted by johnny55
was their somwhere in this tread where someone posted pic.s on how to build the shocks???? The parts are confusing me Im haulted!!1 DAMNET!!!
#4134
how do we do step A-1? whihc ones r the diff balls n thrust balls? n in the supplemental sheet, wat does it mean by follow the shimming?
#4135
Regional Moderator
#4136
from the pics, i dont see how to install the thrust balls... n where exactly do i put the grease?
... any special tips for sealing the chassis, ill prob do that 2nite or 2morow
#4137
There should be a spare thrust ball for each diff too, should get 6 to fit nicely around the thrust screw.
The standard shimming is one shim on each side of the diff, do it like this the first time you run the car. Then when you go to rebuild the car you can take some time to see how many shims removes the diff play without making it tight and you can use them to push the diff to one side, away from the bevel gear to give a looser mesh which is also quieter
#4138
#4139
Regional Moderator
sandwich between the 2 washers.
chassis prep www.alexracingusa.com has the info there
#4140
thanks guys
