Alex Racing Barracuda R2 & R3
#2327
Some help needed for building
Hi,
Web Special: Yeah, that orange car. LOL
Ok, so I've already sand down the chassis batteries slots and CA all the graphite parts. Now doing the shocks but I'm getting stuck since its all written in Japanese and my brother Jimmy is not here to help.
1. I'm using the HPI #2 shock pistons that are grey and I find that the black shock pistons that came with the kit have the same size hole as the HPI ones. The stock ones fit more sluggly then the HPI ones so is that correct?
2. Also, there are 2 types of 0-rings, black ones and white/clear ones. Which of these goes first toward the top?
3. There are also washers and spacers on the parts tree, but it does not specify which is which to use.
Can one of you experience guys help me out here?
Dan
Dan
#2329
Originally posted by ImGoinRCn
Teeth, I think Dave has the manual in english...helped a lot since he made it AFTER I built mine...it's been a while since I built mine...
Dan
#2331
Originally posted by rc-zombies
me too....
me too....
Dan
#2333
Re: Some help needed for building
Originally posted by Maj. Teeth
Hi,
Dan
Hi,
Dan
1) my memory thinks the stock pistons are white.... you may have the wrong parts, as the kit items don't come on a tree, I think they come in their own little bag. Just checked Speedtech website and the the pistons are white (Alex Racing uses a few Yokomo parts tree's so lots of bits you don't need )
2)The O-rings for use in the shocks are the clear/whiteish ones, the black rubber o-rings are for use in the one way drive cups
3) Steve included an extra sheet for helping when building, that included details on which spacers to use. From memory, first it's some white ones which have a smaller radius section that fits in the alloy shock end, then there are rubber o-rings (two I think), a spacer (not sure which one) think it's small and black, then a larger black spacer which has a flat on one side, you then put the metal clip in place to hold it all together and the straight section of the clip sits on the flat of the last spacer. Also remember that the rear shocks use an extra small black spacer on the shock shaft itself, it's one of the smaller radius ones but is a little thick.
Hope that helps, too tired to fetch my manual from the living room
#2334
me too....
me too....
well actually the japanese one isn't that bad, it has lots of helpful pictures, (although some contradict each other)
#2335
Hi,
Dan
Hi,
Dan
Sound good...
-Dave
#2336
Re: Re: Some help needed for building
Originally posted by JDM_DOHC_SiR
Tell ya what I`m going to do for you all ...give me a Day and I`ll show you some detailed pictures of how the shocks go and some other little tricks for them...
Sound good...
-Dave
Sound good...
-Dave
sounds good though, especially if you get Steve to put it up on the website
#2337
Re: Re: Re: Some help needed for building
Originally posted by Herminator
sheesh, you have your own way of doing things for everything
Steve if your reading this...Take notes...
-Dave
#2338
Re: Re: Re: Re: Some help needed for building
I have had a lot of good things that I have posted here but they never seem to end up on the ALEX site
-Dave
-Dave
#2339
Re: Re: Re: Re: Re: Some help needed for building
I think he may miss it amungst all the junk we post on here too or those long sigs distract him I think we can forgive him on the sig thing, he's not been racing much so his finger will be tired, concentration will be hard to keep up when your digits are tiring
#2340
Herminator,
Thanks. Strange how my shock parts are all on the black tree and nothing resembles the the look of the manual parts.
JDM,
Thanks and I really appreciate that. Hopefully once built I can post a picture of it here. I know this is not the easist of cars to built but it looks really solid so far.
Dan
P.S. Now, could it be that because this is the web version, its different then the other cuda? reason is, on the english supplement sheet, it said to take #2 of the part tree yet, its a spring spacer guide. LOL..
JDM,
Dan
