Alex Racing Barracuda R2 & R3
#2266
Originally posted by Ko Racer
well bro half of each sheet is coming your way with your mag and DVD of the reedy race
Also today I was doing some light work on the Purple Cuda` and I cleaned out my Squat Bearings today and cleaned up and reshimed everything...and the drive train is so free that I can blow on the spur gear and make the drive train spin!!!! ..thats a 1st for any cuda that I have owned!!
-Dave
#2268
Re: Re: Web Special
Originally posted by rc-zombies
my good buddy Dan... got the second Web special from Steve...
anyways glad to have you on the thread now Zombies
-Dave
#2270
Re: Re: Re: Web Special
Originally posted by JDM_DOHC_SiR
I hope you guys can get the Drive systems for them still...in Orange that is..... they only made so many of them
-Dave
-Dave
Dave...
Where can I get the Pal drive system in Orange?
Glad to finally be part of the thread... I've been following the car for quite some time...
#2271
Hey Dave, those shims you talked about for the small bevel gears, do you have a part number for them? will have to see if I can get them in the UK. They must be a tight fit as my cuda doesn't seem to have much, if any, play in the small gears. From your discription you seem to be pushing the small gear towards te larger gear for a tighter mesh yet you shimm the diff so it's a looser mesh strange how it makes things quieter.
I'm still getting laughed at for my tractor
#2272
Re: Re: Re: Re: Web Special
Dave...
Dave...
-Dave
#2273
-Dave
#2274
I have to dig it up...but I`ll find it for you.... I just measured some more gears tonight and I just found out that alex makes 3 gears now..!!! ..ohhh well the new new new...ones only need a 0.1mm shim an the 1st R2 ones need a 0.2mm shim and the R1 gears need 0.3mm shim... also it make the car more quiet because it keeps the gear from going back and forth..
-Dave
-Dave
#2275
LOL, maybe soon they'll make a newer one that needs no shims
thats what I think they did with the Newest set of gears..that ALEX Racing just made about 2 months ago ... ..
I`m just picky with the car being quiet since I spent almost 2 weeks making this shim thing work
-Dave
#2276
Regional Moderator
Re: Re: Re: Re: Re: Web Special
Ask Steve at Speed Tech if he can get it for you 1st....and if he can`t then try Ko`s Importer..and if that doesn`t work...I`ll se what I can do....but you had better act fast....really fast like try to find out by friday next week if you can 100%..because I think that they only made 50 of the Orange drive systems...and I know of 25 of then that are being used right now in the Tokyo/ Yokohama area..
-Dave
-Dave
#2278
R/C Tech Elite Member
Re: Well.....
Speedway Pal now is going to release a Right Motor Drive system to go along with the ALEX Right motor chassis... But they will be in limmited #`s just like the Normal PAL drive system..... they SHould be out the 1st week of september...
-Dave
Have a look at the Pic` so for all of you that want a right side motor and don`t want to pay for the Web R2...here is your chance to get them
-Dave
#2280
-Dave
-Dave
