Old 03-03-2003, 05:04 PM   #1
Wilfred's Avatar
Default Need correct info on tire inserts.
I run in concrete race track, temp runs from 30-40 deg. I need help on this, I'm using a Sorex 36r tire. What insert should i use? firm, mid or soft? i run 11 dbl motor, should there be air gap or non?
Wilfred is offline   Reply With Quote
Old 03-03-2003, 06:10 PM   #2
Lab-driver's Avatar
I use HPI blue- but I run on asphalt, not concrete so you might want to try HPI greens.
Lab-driver is offline   Reply With Quote
Old 03-03-2003, 07:30 PM   #3
rtypec's Avatar
Default Sedan Tires and Info 101
I believe this article was written by the one and only DJ. Enjoy!
rtypec is offline   Reply With Quote
Old 03-03-2003, 08:18 PM   #4
mo's Avatar
With 36R tires, I almost always run Yokomo Firm inserts. Especially in the hotter temps. Our track gets up to 165deg F, in the summer time. In the hot temps, you definately want some air gap. It seems like this helps keep the tire from overheating.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
what is the correct way to use tire warmer? straightaway Electric On-Road 4 12-09-2006 02:00 AM
What tire inserts are which? Marc_05 Australian Racing 7 06-13-2006 03:40 PM
tire inserts RKeasler Electric On-Road 16 05-19-2005 04:33 PM
Tire inserts 20%nitro Electric On-Road 1 03-23-2005 08:07 PM
tire inserts hierog Electric On-Road 19 12-21-2003 07:19 AM
SEO by vBSEO 3.5.0
