How To Gear Novak 13.5
#31
Originally Posted by Turtlemaster
for me and yok bd, the 13.5 likes a tall spur gear 112, pinion is a 40 final ratio is a 5.6, i have the upgrade rotor installed. temp is 125 degrees, but we are running 8 minute heats and mains. i did try higher ratios, lap times were the same but the temp went up. hope this helps.
#32
I have anovak speed control so do i still use #3?
#34
ok
#35
Originally Posted by jenesis
Sounds Good! Turtlemaster Thanks! I would try maybe down to 35t pinion and work my way up!
#37
R/C Tech Elite Member
I'm curious what track conditions you guys are racing in to have to gear the motor that hard. I got 130-150 degree temps out of the motor running the same ratio I'd use on a CO27 stocker. Track temp was 120, running Sorex 36 rubber on a medium technical asphalt circuit.
To give you an idea, most guys running the 5.5 Systems ran at 14/87
#38
foam
#43
i assume your gonna be racing at norcal seeing how your sig says union city. mid 5's should be fine for thier track, both of them. i haven't ran there just visited over thanksgivin, (i grew up in fremont).
#44
Originally Posted by Advil
Run 5.2 at NorCal with the 13.5. If you need any help while you are there just ask for Art.
(edit) with the sintered rotor...
Art
Art
#45
Fo sho! Art... What days do you usually race/practice?
Art
