Old 12-27-2006, 06:57 PM   #1
Default tight
can anyone help me with this. all the turnbuckles with the ball cubs on the ends at very tight. every time you try to move them with the turnbuckle wrench they come off the balls. does anyone have any help on how to make them more free. any help would be great
xxx-s is offline   Reply With Quote
Old 12-27-2006, 07:51 PM   #2
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Take the ball cups of the teurn buckles and try alittle bit of graphite grease like they use in the pine derby cars axles.
CarlosG. is offline   Reply With Quote
Old 12-27-2006, 07:53 PM   #3
You can try coating your turnbuckle treads with diff grease or sort to lube it...Its still tight enough to hold the setting...
Ben.C is offline   Reply With Quote
Old 12-27-2006, 08:13 PM   #4
scoobydo's Avatar
Usually when I have that problem, I just unscrew the ball cups and then just simply screw them back in.
This is sometimes enough to loosen them ever so slightly.
Lightly using lube as stated is also very common.
scoobydo is offline   Reply With Quote
Old 12-27-2006, 09:15 PM   #5
wallyedmonds's Avatar
try a bar of soap.(dry) rub it on the treads this is something guys did a long time ago.
wallyedmonds is offline   Reply With Quote
Old 12-27-2006, 09:42 PM   #6
SoCalMitch's Avatar
Take a pair of pliers and squeeze the end of the ball cup where the turnbuckle screws into the ball cup. You do this with the turnbuckle screwed into the ball cup.
SoCalMitch is offline   Reply With Quote
Old 12-27-2006, 11:40 PM   #7
fraz's Avatar
Send a message via AIM to fraz
Make absolutely sure you haven't threaded the turnbuckles too far. By doing so you can easily distort ball cups. Ask me how I know
fraz is offline   Reply With Quote
Gearing Tight? Drift_Buggy Electric On-Road 3 05-28-2008 01:20 PM
Tight track RKeasler Electric On-Road 2 04-16-2008 08:32 AM
Pinch too TIGHT! rcfoolz Onroad Nitro Engine Zone 28 03-18-2008 04:41 AM
Tight servo robotdoblador Radio and Electronics 6 02-08-2008 07:54 AM
To tight of a pinch? pinky2252s Nitro Off-Road 3 11-25-2007 02:15 PM
SEO by vBSEO 3.5.0
