Old 12-18-2011, 08:49 PM   #31
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Originally Posted by TonyK View Post
Since, we are having a discussion of bearings. What is the proper way to clean them?
On my onroad cars:
I usually take a rag dampened with motor spray and wipe the external seals to remove as much dust and debris as possible before anything else.
If you use rubber sealed bearings, you can carefully remove the seals with a hobby blade, then use the RPM bearing blaster with your cleaner of choice to flush them, inspect/listen for free spinning, relube with a high quality oil and reinstall the seals.
For shielded bearings I'll try to clean them without removing the shields the same as above and relube.
Plenty of places offer $1 bearing multi-packs [10/$10], so any suspect bearing gets replaced.
For my off-road cars:
Leave the factory lube in the bearings, wipe the seals with a damp rag as above, feel for any drag or grit. Replace if any is found.
Almost never have any luck trying to clean bearings in an off-road vehicle.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 12-19-2011, 05:12 AM   #32
Originally Posted by squarehead View Post
Hmmmm... not an option. Kind of need those shields on the bearings. So no other way to tell, eh? Damn, that's kind of dumb.
You can not weigh them?
The ceramic bearings should be somewhat lighter in weight.
dark_luna is offline   Reply With Quote
WTB: CERAMIC BEARINGS dynasty R/C Items: Wanted to Buy 0 12-12-2007 10:40 AM
Ceramic bearings for my T2 Got Xray? Australian Racing 33 08-21-2006 12:14 AM
TC4 Ceramic Bearings BBSpence R/C Items: For Sale/Trade 3 01-11-2006 09:17 AM
Pro-4 with Ceramic Bearings ssdrop64 R/C Items: For Sale/Trade 16 05-02-2005 09:35 AM
Ceramic Bearings PhatPat Electric On-Road 15 11-25-2003 06:10 PM
SEO by vBSEO 3.5.0
