Old 12-22-2006, 01:24 PM   #1
Default LRP 7.1
Hi all,
Having a problem which I was curious if anyone might be able too help out with a LRP 7.1
Everything worked fine then
I just installed one and am having an issue. I have it installed with a digital servo and running a M11 with a spectrum kit. Whe I turn it on I get a lot of chatter from my digital servo, doesnt twitch at all, but I hear a constant buzz from it.
But If I install my regular FM transmitter in my radio it works fine? I tested it buy installing a different speed controller and it worked fine so I dont believe its my radio or spectrum set up
any ideas?
FiremanKen is offline   Reply With Quote
Old 12-22-2006, 01:40 PM   #2
Send a message via AIM to $rusty$ Send a message via MSN to $rusty$
Did you bind your spektrum yet?
Rusty Andersen
$rusty$ is offline   Reply With Quote
Old 12-22-2006, 01:52 PM   #3
Send a message via AIM to airborn
I have had a similar problem, I used to use synthesised JR recivers with LRP QC2 ESC when i went to digital servo glitching and low power symptoms just like you have described occured. I tryed a novak GTR esc and no problem I used the lrp with crystal FM recever no problem, JR could give me no explanation. What I found out is LRP has a lower bec voltage than novak not the new QC3 but all the older stuff like your V7 and my QC2 the synthesised recever must have required more power or could not transfer enough power not for sure but this could be the same issue you now are faced with. I had to change my carws with the digital servos to crystal receivers since I did not want to go back to anilog or buy a novak esc.
digital servo requires more power
LRP has a slytly lower bec voltage
novak has a slytly higher bec voltage
crystal receiver works the best
synthesised receiver may require more power?
spektrum may require more power?
hope this helps
airborn is offline   Reply With Quote
SEO by vBSEO 3.5.0
