Old 12-21-2006, 12:17 PM   #1
Racingfreak6's Avatar
Default Power supply question
I have a power supply that is 14amps and am wondering if that is enough to run 2 ice chargers at the same time?
Racingfreak6 is offline   Reply With Quote
Old 12-21-2006, 12:23 PM   #2
N4S's Avatar
Unless your charging each pack at over 7amps..... ......... Yes. This is assuming its a good power supply that is a true 14 amp supply ....
N4S is offline   Reply With Quote
Old 12-21-2006, 12:48 PM   #3
14 amps should be fine for just charging...
but if your going to be running motors, AND charging at the same time that can be a problem. I've seen lots of problems where people build motors that pull 9-10 amps @ 1.5v for racing. add this to using 6 amps to charge, you will then max out that 14 amp. Or run your motors in at a lower voltage for breakin/cleanout.
Just something to think about.
MManson is offline   Reply With Quote
Old 12-21-2006, 12:54 PM   #4
Anthony.L's Avatar
Trader Rating: 36 (100%+)
I would suggest you don't charge at more then 6amps while running both chargers.
FYI, you can get a 24amp power supply at Radio Shack for around $100. That would run two charges up to 10 amp with some left over.
Anthony.L is offline   Reply With Quote
Power Supply Question Newell33 Electric Off-Road 19 07-12-2008 01:39 PM
Power Supply Question cutwo Rookie Zone 1 12-27-2006 08:43 PM
power supply Question James605 Electric On-Road 6 04-23-2006 05:30 PM
Power Supply/GFX Question tc3blue Electric On-Road 8 10-04-2005 12:11 AM
Just got my power supply and i have a question wallstreet Rookie Zone 8 05-12-2005 03:46 PM
SEO by vBSEO 3.5.0
