Yokomo MR-4TC SD
Originally posted by JayBee
Hey Steve,
This is a pre-order pre-request... PUT ME 1ST ON THE LIST - JB
Hey Steve,
Better add me in there Steve...I will let Jaybee in and put me in there fifth. At least you will get that many anyway. Right Steve...
Thanks again for the great service Steve......
Steve for ROAR President.....
Stephen <><
Stephen <><
I have some problems with my CGM setup. It enters very good (perhaps a little bit too hard) into the corner, but pushs way too much in mid-corner and exit.
My Setup:
Front:
Dampers
down: third hole from outer
damperstay: outest hole
Springs
Yokomo orange
Oil
Associated 40wt
Piston
Droop
7
Camber
0.5
Toe
0
No swaybar
Rear:
Dampers
down: outest hole
damperstay: third hole from outer
Springs
Yokomo green
Oil
Associated 40wt
Piston
Droop
5
Camber
0.5
Toe
3
No swaybar
Others:
Tires
CS-27 or Sorex 28R
Body
RIDE Honda Accord TSX
I hope someone can help me.
My Setup:
Front:
Dampers
Springs
Yokomo orange
Oil
Associated 40wt
Piston
Droop
7
Camber
0.5
Toe
0
No swaybar
Rear:
Dampers
down: outest hole
Springs
Yokomo green
Oil
Associated 40wt
Piston
Droop
5
Camber
0.5
Toe
3
No swaybar
Others:
Tires
CS-27 or Sorex 28R
Body
Originally posted by speedy-932
[B]I have some problems with my CGM setup. It enters very good (perhaps a little bit too hard) into the corner, but pushs way too much in mid-corner and exit.
My Setup:
Front:
Dampers
Springs
Yokomo orange
No swaybar
Rear:
Dampers
down: outest hole
Springs
Yokomo green
No swaybar
B]
My Setup:
Front:
Dampers
Springs
Yokomo orange
No swaybar
Rear:
Dampers
down: outest hole
Springs
Yokomo green
No swaybar
B]
- swaybar would help inital turn in / smooth it out = not so twitchy
- camberlinks are very important; are you running stock locations? ive found going up one hole allow the car to hold better/tighter lines = holds the line in & out of the corner.
rear';
-with you current setup, your rearend maybe push the car straight.
- try moving your rear shock 1-in on the arms (3hole for in) = not so machanical grip
- try #2 toe in. = not so much rear traction
Thank you. I will try some things at the track tommorrow.
are you running a diff, oneway, or spool in the front?
Oneway.
broken drivepins
Hi,
i keep on sanpping the pins that attach the axel to the dogbone when i am runing a spool. i must of gone through about 15 of the pins. it always seems to be the front right wheel everytime, i hav tried replacing the axles and theactual dogone but cant stop it.
i only race 27t indoors and yes i do crash and it does break then sometimesm but others it just randomly breaks?
i hav just been trying it on the road outside my house where it has randomly snapped today, but today it didny and i was going for about 20minutes so i am confused with what could be causing it?
is it that the bin grub screw holding the pin in place comes undone slightly so the pin moves along and so the pin is snapped becuase there is more force over the little area? is there anything i can do to stop this if it is?
or is there something that i have missed?
many thanks
A Gower
many thanks
A Gower
STOP HITTING BOARDS!! JK
Are you using threadlock?
Re: broken drivepins
hows your maintenance ethics, i relube my every 3/4 runs.
put a little blue thread lock on the grub screw before reinstalling them and if you don't have any good wrenches, get some, they help a slot too. I have found that running a spool or oneway all ways tears up the drive train in the front end.
what size tool do i need? ive got hudy wrenches but the pinion size one doesnt quite fit in properly, it is abit to small. you can use it but it doesnt go in all the way?
so wot size is it?
many thanks
A Gower
so wot size is it?
many thanks
A Gower
1.5mm
so wot size is it?
many thanks
A Gower
so wot size is it?
many thanks
A Gower
pinion, here in the US most are 1/16" or .050" (but i believe 1.5mm come with the kit)...
if your going to work on this car, you need 2 or 3 quality wrenches 2mm / 1.5mm / pinion wrench (1/16")
if it doest fit, dont force it... i know i goes agains all male intuition; but attention to detail is why some finish races and some keep breaking.
My Setup:
Front:
Dampers
Springs
Yokomo orange
Oil
Associated 40wt
Piston
Droop
7
Camber
0.5
Toe
0
No swaybar
Rear:
Dampers
down: outest hole
Springs
Yokomo green
Oil
Associated 40wt
Piston
Droop
5
Camber
0.5
Toe
3
No swaybar
Others:
Tires
CS-27 or Sorex 28R
Body
My Setup:
Front:
Dampers
Springs
Yokomo orange
Oil
Associated 40wt
Piston
Droop
7
Camber
0.5
Toe
0
No swaybar
Rear:
Dampers
down: outest hole
Springs
Yokomo green
Oil
Associated 40wt
Piston
Droop
5
Camber
0.5
Toe
3
No swaybar
Others:
Tires
CS-27 or Sorex 28R
Body
