Yokomo MR-4TC SD
Originally posted by Evoracer
Hope this doesn't sound TOO dumb but....do you guy's actually drive the Worlds Edition SD ?? I'm interested in trying one but with only 555 made....I wonder if it's more of a collectors item. It looks great though !!
It's a beautiful looking car, but it's defintiely a collectors item really. The new Yok BD will be the next 'big thing' and I suspect it will be far more practical to race than an SDW.
Originally posted by Horatio
Shaft drive with open gear boxes - it better only be run on very well prepared surfaces. The track it was raced on at the worlds was meticulously prepared.
Originally posted by Turtlemaster
....little rocks, and sticks and stuff everywhere. after quite a few packs through it the rear diff, had a little clicking noise from ity bity stuff in them but it still rolled free.
If I owned one, I'd fashion some lexan covers to help ensure nothing got into the gears. The car is definitely special. I wouldn't be able to justify racing it though - I just wouldn't feel worthy!
has anyone ran their car SDW in stock carpet racing?
would like to get some input on how it handles.
Thanks in advance!
Thanks in advance!
Hey SD guys, I'm building a CGM right now ... I got the titanium screw kit and precision bearings already. What other hop-ups would you say are most effective? I got those two to start because that's the best time to install them, otherwise you have to dismantle the entire car.
I'm thinking a carbon fiber driveshaft, lightweight input shafts, and some .5 and 1 degree rear hub carriers. What others would you suggest?
Hope this helps,
Stephen <><
I would have to say besides the wide front bumper you should be set. Ive never ran the 1 degree hub, maybe a half. The input shafts yes, but Im not sure about the driveshaft either, Ive always ran the stock one.
K, I'll add the wide bumper to my list ... since I do tend to hit everything in sight I have a carbon driveshaft on my SSG, I can swap it into the CGM and see how it like it. My thinking is that I'll run the SD in stock and 19turn, so that little bit of less rotating mass should help. Also it's possible a cf shaft might flex a bit, and lessen torque steer?
Then I'll run my Tamiya 414M2 in modified until I get my new Yokomo BD
[B]has anyone ran their car SDW in stock carpet racing?
Thanks in advance!
Hallo i have tested the SDW in 27 stock and 19 stock on sorex 28
Im faster whit the SDW than i was whit the CGM on carpet
it has more steering and reacts better
Thanks in advance!
I would imagine the CGM does pretty well on carpet ... the chassis is as stiff as anything I've ever seen! The only car I've seen that's close is my RC Lab.
TurboFC3S:
the yokomo's own CF center drive shaft will flex like a noodle
during mod and it is also heavier(the older version).
try to get the SDW's drive shaft. it is much stronger and
lighter.
hope this help
~ming
lighter.
hope this help
~ming
Thanks Ming ... I'll get the SDW one then
Thanks all. So what's the parts supply like for the SDW ?? Are the parts that are unique to the Worlds car available?? Is the whole car unique or are some of the parts the same as a regular SD ??
