Yokomo MR-4TC SD
#7081
Originally posted by nitro_tacklebox
So being a board slapper myself...what parts are essential to have in the tool box to have as replacements when my driving takes its toll on the car?
Assembly was great, although the instruction manual could have been a little more forthcoming with setup details during installation. Did anyone else have a heck of a time with freeing up the drivetrain? I played and played with shims untill I finally was able to free it up to a point where it rolled just like my TC3.
For running on carpet do you recommend the one-way? I know the answer will be yes, plus it will eliminate having to tune 2 diffs by only having to worry about one.
Sorry for all the questions, but this Yok is the "unknown" where as my TC3 is all set up for action.
Thanks!
Thanks!
Wishbones - get the graphite ones
Steering Arms - get the alloy ones
C - carriers/rear hubcarriers - get the H or G versions
King Pins
Also, it's wise to machine the driveshafts to prevent the the CVD joint form seizing.
Set-up the transmission EXACTLY as it states in the manual. The mesh needs to be bedded-in first. If it's really 'free' before you've even run the car, you may damage the transmission when you hit something. Remember - your TC3's tranny has been used for a season already, so that's why it feels nice and free in comparison to your new car. However, if you want to reduce friction in your SD, remove the grease from the bearings and use WD40 thin oil instead. Within a couple of races, your SD will be super free.
#7082
I've posted this earlier.
TITANIUM C.V.D.s
Titanium Racing's most innovative product to date. It's revolutionary 6-4 Titanium CVD. Featuring ball bearing loaders for added durability makes this the no. 1 on the market.
All CVDs feature 6-4 Titanium Drive-shafts and Axles. Produced as a direct replacement for standard kit items, these units are precision made for unparalleled performance.
Increased operating angles ensures that no binding will occur at full lock and its simple design makes rebuilding and maintenance easy.
Steel versions of the CVD's are available for all cars.
_
Features:
_- Reduced Rotational Mass for faster acceleration
_- Reduced unsprung weight for better road holding
_- Designed for better steering characteristics
2504F Yokomo MR4-TC SSG SD Front - Titanium C.V.D. £34.99
2504R Yokomo MR4-TC SSG SD Rear - Titanium C.V.D. £34.99
TITANIUM C.V.D.s
_
Features:
#7083
when it comes to mould machines, they costs between £4-20000, a mould for example gearcases costs about £6000.. (i have some experience with this and know the prices roughly) the material costs nothing, so if you are going to do a big production then a mould is a cheap thing in the long run..
How is the CMG on carpet with rubber tires BTW? compared to the SSG and Black graphite car.. I`m looking to get a SD, but not sure of what model to buy..
#7084
Re: MIP CVD Installation
Originally posted by TKG 27
Hey Guys,
I purchased a set of front MIP CVDs and axles and installed them this weekend. When I tightened the wheel on, the bearings got squeezed and were very tight. It appears the pin hole in the MIP axle is large diameter than the stock Yok one and the hex hub gets tightened in closer to the bearing and locks it up.
Anyone else come across this and have a fix? I am thinking a bearing crush sleeve (like the TC3) or different hex hub pin woud work but have not started looking into it yet.
Jeff
Hey Guys,
Jeff
#7085
Re: Re: Re: MIP CVD Installation
Originally posted by Randman
They aren't made for the SD yet, but the old MR4TC ones are supposed to fit.
We'll see if RC-Zombies can shed some light on the problem.
#7087
Thanks for the replies on the MIPs, guys. Maybe its only guys named Jeff that have this problem.....at least I am not alone.
I checked the hubs for bearing seating. No flash and the bearings were pressed in tight. I had the same issue on both sides and I was also using the pins from the kit. More investigation is obviously necessary.
Jeff
Jeff
#7088
Re: Re: Re: Re: Re: MIP CVD Installation
Didn't think so, but 1 person seems to be having the problem.
I'd check and make sure the bearings are pushed all the way into the hub.
#7089
..... Maybe its only guys named Jeff that have this problem.....at least I am not alone.
Jeff
Jeff
But seriously though, are you using the kit wheels? If not, check if your wheels are causing the bind.
#7090
TKG:
One more thing, I am not using the O-rings for the front outdrives.
#7091
Rebuilding my SD for the first time (bought allready assembled) and Im getting binding on the rear of the car (its the only thing installed thus far. It is like the diff gears is rubbing on the case. I have three shims on the small gear. I've walked away three times and come back to it with the same results. The front is fine so I know im just missing something simple. Thanks!
#7092
R/C Tech Elite Member
#7094
The drive gear is not going into the case far enough. The bearings are not seating into the diff case properly.
