Yokomo MR-4TC SD
#6617
So if you want to convert to FULL graphite, you will need to spend quite a bit more (for gearbox, arms, mounts, carriers, ect.). You'll probably be better off getting the whole kit. Oh well.
#6618
R/C Tech Elite Member
#6619
Yeah, get one of those and stick a Yokomo or LRP sticker and tell them it is a prototype.
#6620
Sorry if this has ever been adressed before but there is not a chance I'm reading through 330 pages to find out.
I just got a SSG and it was allready built but not run. I have a bind in the rear of the car. I can rotate the spur and it is smooth to a certain point and then it notchs. It was REALLY bad till i moved the shaft that holds the spur gear out. Now it is just in that one spot. Any got a clue what might be causing it? is it just because it needs to be run in?
Thanks guys!
Thanks guys!
#6621
Registered User
#6623
Bingo! Thanks Aku
#6624
CGM Conversion kit
Originally posted by Matt Howard
just got my conversion done, very nice I love all those little cooling vents in the side of the chassis
#6625
has anyone ran the new chassis yet? how dose it perform? I just built mine but it sure feels heavy. wondering how to make it lighter.
#6627
#6628
Ya I got one of those "magic" integy machines haha. It's actually awesome. lots of times when im rebuilding my car i just throw bearings and other stuff etc. in it and later on when im putting it back in i just put a drop of oil on the bearings and im set. Its a really really good little "magic" machine. The batteries last for a hella long time too.
Highly recommend it
Highly recommend it
#6629
Highly recommend it
Highly recommend it
What sort of chemicals is safe to use in it? Can I just use ordinary motor/bearing cleaner without breaking the machine? Or do you have to use milder stuff?
#6630
Does anyone here polish their bearings? I recall one racer who removes the seals, cleans the bearing, apples some sort of metal polish, spins the bearing on a dremmel, then cleans away the polish and then re-lubes the bearing ready fo use.
Has anyone here tried this?
