Yokomo MR-4TC SD
#6346
Hey guys, just thought I'd let you know that one of this weeks specials at Speedworld Raceway is 20% off Yokomo SD Parts.
http://www.speedworldraceway.com/Weekly_Specials.cfm
#6347
video
hi, at the weekend we made a short onboard video for our site, it is my MR4TC SD but it wasnt handleing too good because it had a heavy digital camera strapped to the front, back end lose as...
take a look
Onboard Video (MR4TC Louth)
take a look
#6348
R/C Tech Elite Member
Originally posted by forty6
Yup.
Yup.
Front -
Yokomo pink spring
40 wt AE oil
RS 3x1.2mm piston
5'th hole in on shock tower
3'rd hole in on arm
camber link mounted on bottom outside hole on shock tower
middle camber link hole on C hub
1 way diff
7mm droop
arms spaced back
62mm long shock
1.25 camber
1mm shim under spindle ball stud for bump steer
Rear -
Yokomo white spring
40 wt AE oil
RS 3x1.2mm piston
2'nd hole in on shock tower
2'nd hole in on arm
3'rd hole in on hub carrier for camber link
5mm droop
arms spaced forward
64mm long shock
1.5 camber
1mm anti squat
Double upper deck
center chassis stiffener
6mm ride height (bumpy track, drop to 5 on a smoother track)
8.18 final drive with Epic Binary stock
#6349
Originally posted by AzNDRAGster
I like a light car with a low Center Of Gravity.
#6350
Re: video
take a look
take a look
#6351
Re: video
take a look
take a look
nice video...but it made me dizzy..
#6352
yeah it made me abit dizzy watching it for the first time..
#6353
Yokomo has an in car video in their forum section.
#6354
I know one shouldn't ask two different questions on one post, because only one will be answered, but I can't help myself... that's why, later on, I have to ask again
soooooo.... has anyone tried to use blades (schum, xray, ...) on their yokes?
Thanks,
Paul
PS: thanks for the "rose" explanation
Thanks,
Paul
#6355
Thanks,
Paul
Thanks,
Paul
#6357
Tech Legend
Trader Rating: 51 (100%+)
The Schumacher blades also use a small pin to hold the blades on. I use to race their cars for years and remeber the pins are the small size, almost like the ones used in the CVD's to connect the bone to the axle.
#6359
Video Cameras
I went to local meeting where I guy had rigged up 2 minature cameras with transmitters, with 2 seperate monitors complete with the receivers plugged into VCRs. During the day, both the cameras were used during the actual races on numerous cars - it was hilarious!! The racing was far more entertaining watching it from the on-board cameras - you really felt the speed. If you were small enough to clim aboard I'm pretty sure the G would be awesome!
The thing is, it turned into an expensive game of tag - who could get the most spectacular crash caught on video - priceless!! By the end of it, everyone was dizzy and the cameras couldn't cope with the shock loadings BUT the video caught some impressive take outs
Stuff like this attracts spectators - it's what the sport needs.
Thanks for posting the video - it's great!
