Yokomo MR-4TC SD
#5236
Originally posted by utieh
how is it possible to put the front shock end at the second hole (from outside), the wheel (24mm) will touch the shock end until 45% of Dual-rate...
So now I have to use the 3rd hole...
#5237
Cool Chris- good to see that I was on the right track and not feeling things in the cars setup that were not what I was thinking I was doing...lol I first made this change when running on carpet with rubber tires and the car was like a rocket getting into the corner.
Does Yokomo make a 0 Degree Kick piece for the SD? I think the stock one is 1 deg kick.
Jeff
Jeff
#5238
Jeff, just add the notched shim in the back block. Or you can buy the Aluminium blocks (both fronts) that are set at 0° kickup.
Rand... I thought the kit knuckles were offset 1mm. And you can buy the optional 0mm offset knuckles or get the Team Suzuki knuckles that are .5mm offset. Also, Rand... did you try standing up the shocks to make it feel more agressive? And did you play with rear droop? I found it also helps with a loose rear end.
#5239
any one know where I can order Square products? I seen on a Japanese site that square made some teflon spacers for the arms. The ones on my car are a little screwed up from trying to put the car together in a freezing cold garage. cold + plastic = *SNAP!@#$%
Chris T, who makes the white ball cup you are running and the Yok battery strap?
#5240
R/C Tech Elite Member
#5242
#5243
Hi friends. Greetings from Malta.
Haven't been in for a while but I'm impressed. Chris T in here too. WOW!
I still run my 2 SDs. The standard looking SSG car I now run in 21 turn stock, but I have done quite a bit with the mod car since the pics in Yoke USA site.
I am now using a front spool with Rayspeed towers and top plate, and I have made a 3.5mm carbon chassis myself. This has the Rayspeed steering geometry and has the cells further forward and more towards the centre. It feels much more responsive.
The Yoke carbon centre shaft didn't last with mod so I am back with the shortened TC3 carbon one which is the lightest of the lot anyway.
I have just received the graphite arms, hubs and diff cases and will put those in before the weekend.
Next outing with mod: Christmas Cup meeting, 21st December.
Regards
Joe from sunny Malta.
Regards
#5245
Originally posted by Randman
precisionrc.com has the Square stuff at a good price with fast shipping. The yokomo battery strap is a SSG piece made for the SSG MR4TC Special.
#5247
Tosolini's Cleveland Setup Sheet
For those of you interested in downloading Tosolini's setup from Cleveland, here's the link to the pdf.
http://www.yokomousa.com/manuals/sd_...eveland_03.pdf
#5250
I'm not sure how accurate this is but check it out...
http://www.schumacher.clara.net/springchart.htm
