Yokomo MR-4TC SD
#2836
Originally posted by Tsubasa Sakai
Rayspeed Edition will be available in complete kit.Maybe its parts will be under Rayspeed brand too.
#2840
I realy want to try my Yok without the center brace, but I am not sure if the chasis can stand on strong impact without the center brace......I normally run my Yok on asphalt track with a lot of traffic. Regard.
#2841
Hi guys. Greetings from Malta.
I have removed the centre brace on both my SDs. You don't need that sort of rigidity on asphalt.
So have Adam Rogers and Chris Grainger who are the two quickest Yoke SD drivers in UK.
Regards
Joe from sunny Malta.
Regards
#2842
Re: Mid-turn understeer
Originally posted by IH
Hi guys,
I raced with my SD yesterday and I was very happy with the setup of the car. Very easy and smooth to drive. The only thing
I couldnīt get rid of was some mid-turn understeer.
Turn-in and corner exit were quite perfect.
Drove the car with 2 diffs. no swaybars. rear:green springs
front: yellow, 40wt f+r, 3 degree rear toe-in.
Any suggestions?
Thanks,
IH
Hi guys,
Any suggestions?
Thanks,
IH
Front 45wt, rear 40wt, stock spring.
Hope it help.
#2843
been running the yoke without the center deck for quite awhile now and didnt seem to notice much difference so why carry the extra weight hehe
#2844
Rayspeed SD
Rayspeed SD will be available after September.The approximate selling price is 333.3USD.
#2845
Re: Rayspeed SD
(perhaps $333,33 is the price of the chassis )
#2846
Yes, it is made of this super space age graphite that NASA only uses!! No, it would the price of a complete kit.
#2847
Rollcenter question?
There are Eight spacers total do u use all four for the front and four the rear?
#2848
Jeff Werner,
Did u put the spacer in the rear of the car too or just the front? Use all four spacer for the front right?
Sorry guys for the muiltple posts. Just trying make sure.
C
C
#2849
Mo and Analyzer,
Thanks you for your suggestions. I will post results as soon as I have done some testing.
Regards,
ingo
Regards,
ingo
#2850
Joe n Koya Dale.com,
Thank you for the response. I will try my Yok without the centre brace after my race on sunday.
