Yokomo MR-4TC SD
#2626
SET BOOK
I noticed someone post a link for explaination of tweek.
Here is a book i highly recomend. Its a setup book in real english. Its for touring cars only on rubber or foams.
mPowered Chassis Setup Guide
#2627
Originally posted by NightKidZ
Allistar : Where can I get pics of the Rayspeed SD? I know its reviewed in the Aug edition of RCWORLD but I can't find it in Kinokuniya last I checked. Does Jerry have the mag in his shop? Thanks
#2628
Sorry for my ignorance, but how do you make that determination (which bar to use for which track)? The track I run has wide open banked sweepers with a tight infield, so I am sort of looking for a little of each. Would switching to an upper sway bar help with the sweeper but hurt transition quickness? How would that change the balance of the car (i.e. front bar only)?
Granted, I am just starting out with the car and I am a poor driver to begin with (but improving). I am just trying to see how mounting the bar higher (or lower) would affect the balance of the car at that end. I know there are a ton more settings I need to learn about, I was just trying to determine where I should start with the sways, that's all.
#2629
Anyone got the black version yet?
#2631
Did you guys get to compare the weight difference? People are saying that the black ones are suppose to be lighter and stiffer. Any truth to this?
#2634
Rainbowten has the black pieces....
#2635
Is anyone running the SD on carpet with foams? Are you intrested in a stiffer chassis and top deck? I have been running a custom chassis plate and also a 3mm solid upper deck. We are looking at doing up a few for sale and were wondering if anyone would be intrested. These are hand cut and would be very limited. I am waiting for my next shipment of graphite and will be testing some new features on the chassis.
#2636
Tech Legend
Trader Rating: 51 (100%+)
Brian L I would be interested in the toplate. It would be nice to have a another possible tuning tool. Not running carpet right now but might later this winter.
#2637
hey guys im starting to look towards the yokomo but i just have some few questions
1.is there any vital upgrades to the car that i should get right away(im keeping the front diff and will be running in mod class)?
2.(to the people that have both tc3 and the yoke)what are the car strong points compared to a FTTC3?
3.are yokomo spares hard to get?
#2638
First thing i installed on the car was a TC3 Buds front bumper. With some modifications it fits nicely. Cant go fast if your car is broken. The next thing i did was install the AE lower spring retainer clips so i could use all my AE springs
I own both the YOK and TC3(RACER)(FT is a wast of money) And so far i have only broke on steering hub and c-hub both broke without the addition of the buds bumper.
STRONG POINTS:
-its as strong or better then the TC3
-diff access is 2 screws! I clean the diff for kicks now because its so easy!
-slop in the front end is about the same i added orings to the tierods and this took away most of the slop
PARTS:
Online there are lots of places
My local hobby shop here in Ontario Canada brought us in some parts so any hobby shop that wants your bussiness should be able to get them. WE have 3 racers with the SD so the shop felt it was worth while to bring in some spares.
STRONG POINTS:
PARTS:
#2639
Originally posted by James Nguyen
Saw these on the Yok Jp website. I assume they are the same as the stock ones but the ballstud hole is moved forward a mm or so?
It's like the difference between the trailing and in-line axles on an RC10. The SD as standard has trailing steering blocks up front - i.e. the axle line is behind the kingpin line. These new blocks have the axle and kingpin axes crossing, which should give sharper steering. Sounds good to me.
