Yokomo MR-4TC SD
#2581
Hi Guys,
I been wanting to ask, when you guys swap the rear shock tower to the front, does that mean :
1. the rear is using the 'front' shock tower?
or do you buy another 'rear' shock tower to fit in the front?
Thanks Regards!
Thanks Regards!
#2582
Game:
I run at debbies rc world, hobbytown, stream, thercspeedway NC,
goldsboro NC, and mimi's.
rubber tires. The only reason for different spool. IS because I have been trashing the plastic ones. It ends up spining the diff rings on the plastic out drive.
#2583
marzin
You have to buy another rear shock tower. It works the best when you use the spool front diff. It helps you turn in better.
#2584
#2585
KT (Keith?) Try my setup for Goldsboro State Race a few pages back. If you don't have RaySpeed Springs, you can get away with Green Rears and Orange Fronts. As for Droop, I don't set droop for front. I only set shock length. 60mm. Also, when are they gonna have a trophy race again out there? Been wanting to come back up! And when you coming down to Goldsboro?
Jimmy Mac
Jimmy Mac
#2587
Kil your set-up was the starting point Pete and I used
The changes we made were to take out the 1-way due to the bumps.
White front yellow rear
Front bar Silver
#3 on the arm from inside front arm
40wt Pete
50wt Dan
2-hole large piston
The bumps on the track made the car a hint nervous going to the larger 2-hole calmed the car down huge and was good for .2 a lap
Front bar Silver
40wt Pete
50wt Dan
2-hole large piston
#2588
YMP TC2003 prototype?
Don't know if anybody else here have seen this car?
Just thought I would post the pictures here so you can see. Seems like they're busy in Japan... They're not letting the TC rest in peace!
#2589
Saw these on the Yok Jp website. I assume they are the same as the stock ones but the ballstud hole is moved forward a mm or so?
#2591
Jimmy Mac
JMac,
Hey man its good to hear from you again. well as far as the trophy race. I'm not sure. But I don't think that it is until like september or something, but I will check and let you know. As far as racing though. I was thinking about coming down there Saturday if there racing. I just have to see if I can get dave to come down there with me. Oh I have you 30 bucks. can me or something so I can get your address and mail it to you. did you see that speedtech carries them now. Also he is getting in the rear carriers too. I will let you know about this weekend. You said the spool down there right.
keith.
Jimmy Mac
JMac,
keith.
#2592
Thanks!
re: rear shock tower
Thanks Ya'll !!
Thanks Ya'll !!
#2593
TC2003
not TC2003 phototype
#2594
How do I find information about the carbon fiber version of the SSG? Also were can I find pictures of the black version SSG?
#2595
My son raced in the stock class at the same event -- ROAR Region 11 -- as Peter. Sam won the stock class with his SD SSG and set TQ in the first qualifier.
Having Peter and Dan there was a big help. We always learn something new from them.
