Any V2 motor tip & trick? >
Old 12-19-2006, 04:25 PM
James khoo's Avatar
Trader Rating: 15 (100%+)
Default Any V2 motor tip & trick?
I just get my V2 motor,any tip & trick on this motor?please help.
thanks
James khoo is offline
Old 12-19-2006, 04:53 PM
Bolt it in and wire it up!
Go racing, easy as that.
Then you will have some benchmark for your preference.
Matt Dall is offline
Old 12-19-2006, 06:55 PM
Wing Chun's Avatar
Hi James
Make sure you do not over gear it. They have problems with keeping the wires on.Keep the Spring/brush Tube clean. When you pull the trigger on you will see a light in the Endbell, there is a motor capacitor in the endbell with the light to tell you the motor is working fine . If the light does not come on at any time,there is a problem with the motor there is a problem with the motor.Try running the motor at 6 degrees( one line ) advance first and how it goes.
I love the motor's,Great design.
What model and wind are you using?
Good luck
Best wishes for Christmas.
Addam smith
Wing Chun is offline
Old 12-19-2006, 07:13 PM
James khoo's Avatar
Thanks,my Revelution V2 is 7 x2 turn.and i will run it on my xray T2 on gear ratio 8.80.
Will breakin the motor tonight
Old 12-19-2006, 07:31 PM
James khoo's Avatar
Do i need a Schottky on this motor?
Cheers
Old 12-19-2006, 07:37 PM
the shottky diode can be placed closer to the ESC, some people say its not as effective, but i think it doesn't matter. The shottky diode is used to protect the esc actually... (at least to my knowledge). For me 12 degrees of timing works best, (best speed/torque) for my track, but it does wear brushes fast.
Happy Racing (and Merry Christmas!)
rcnewb2004 is offline
Old 12-20-2006, 02:37 AM
Patriiick's Avatar
dont overtighten the endbell, the aluminium can sometimes bend a bit and put unecessary strain on the motor.
Patriiick is offline
Old 12-20-2006, 04:32 PM
James khoo's Avatar
Last night,after the break-in,the motor become hot,it is normal?
i break-in with 2 v with fan
Old 12-20-2006, 07:12 PM
Wing Chun's Avatar
How long did you break it in for?
What amp did you run it at to break it in?
Addam
Old 12-20-2006, 07:28 PM
James khoo's Avatar
I'm using 2 cells(1.2v per cell)break-in till the brush fully seated.then take apart the motor to fully clean on internal,do same light cut on the comm,reoil the bearing.
Correct me if i miss or wrong break-in or something.thanks
Old 12-20-2006, 07:53 PM
Guo Chean's Avatar
from what Joe Pillar told me during indoor champ the regular V2 endbell with the regular sprint brush. 1v break in for 10min. with the new OSJ endbell with the new 3.8mm sprint brush 1v break in for 15min. normally after i clean my motor and cut the com i just break in the motor after that i just run my motor without doing this process again take apart the motor to fully clean on internal,do same light cut on the comm,reoil the bearing.
Guo Chean is offline
Old 12-21-2006, 09:22 PM
James khoo's Avatar
Thanks for the info guys!
