Old 12-14-2006, 09:46 AM   #16
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Originally Posted by wallyedmonds
you will still hurt them,
Taking a IB cell down to .7 will not damage the cell. Only take the cell down that low to eqaulize before charging.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 12-14-2006, 09:53 AM   #17
wallyedmonds's Avatar
only to .9 and realy you dont have to go down that far 1.0 is fine,if you want to keep your cells ok. i know one guy i race with and he dosent even discharge his cells and hes still fast,these cells are very very fragile,like i said you could have dead cells and not even know it.
wallyedmonds is offline   Reply With Quote
Old 12-15-2006, 02:17 AM   #18
t4m1y4niac's Avatar
in Spintec's manual instruction the suggested cut off voltage for IB cells is 1.0 v.then you can Equalize those cells with Novak Smart Tray until 0.9 and then charge them to 500mAh - 1000mAh if you are going not use your cells in a month...if you plan using your cells on the next week you can charge them about 100mAh - 300mAh...your battery will long life..
t4m1y4niac is offline   Reply With Quote
EPA - ABS and D-Rate NOVICE4EVER Singapore R/C Racers 8 02-11-2008 08:04 PM
Pulse vs Linear DISCHARGING (also vs Multi-step discharging) akuhon Electric On-Road 5 01-01-2007 10:58 PM
Discharging and Discharging Question jeffbhhs Electric On-Road 5 12-14-2006 05:34 PM
how would you rate the bk1, bk2 and the cr tony montana Electric Off-Road 3 11-20-2006 05:40 AM
Rate my car tc3novak Electric On-Road 40 11-30-2004 12:20 PM
SEO by vBSEO 3.5.0
