Team Corally RDX Phi
#391
Hi,
why won't the rdx one-way fit? guessing is it because of the size of the bearing? so will the older rdx diff fit in? i've got a few of those and was hoping to be able to use them.
#392
Originally Posted by Electro-MAX RC
Hi,
Just as a note, even though the cell slots are pre-bevelled, you will need to take a bit more off them the make it easier to get your cells in & out of the car as the battery side bulkhead is very low. Not really an issue however as the cells have some scope to sit lower in the chassis anyway.
#394
Originally Posted by wide_mouth_frog
does this mean a NEW one way is in the mists, or will it be a case of a new bearing holder?
#395
The new one way is a lighter unit. The manual shows a photo and its a very small and simple design.
#396
why compromise?
#397
Hello, have anyone notice that in Vitor Corally PHI his front belt is passsing in a incorrect position on the tension post, or it has a meening
#398
My Phi build has progressed from a box of bits to the attached. Parts finish is very good.
I have not installed the belt tensioner... it over tensions the belt in my opinion.
#400
I got bored so I made an editable setup sheet for the PHI.
#401
#402
Can you use the RDX diffs in the PHI? From what I understand the PHI diffs are designed allot like a 1/12th scale diff. Although I have never raced 1/12th scale personally I have friends who do. And they say 1/12th scale diffs absorb allot of impact durring a crash and have to be rebuilt quite frequently. Is this going to to be a problem with the PHI?
#403
#404
#405
You can use the RDX diffs in the PHI. The PHI diffs are only like a 12th scale diff as it uses a 3 bearing system.
