Team Corally RDX Phi
#3197
Same here, only things different from the box were the steering lever and the rear uprights, which both were commericially available, and different shocks.
#3198
Short Wheelbase Configuration ...
I am wanting to set up my Phi with the short wheel base configuration but am having trouble understanding the rear belt implications. I’ve seen posts here before but the discussion seems to end before the solution gets posted.
I’m running the stock pulleys and rear hubs, just need to know what size belt and where to get it. I think the stock rear belt is 213mm (71 tooth), and the shorter wheel base is 8mm shorter, so I assume we need to take 16mm (15mm or 18mm since the teeth are 3mm apart) from the belt making it a 195mm (65 tooth) or 198mm (66 tooth) belt. Is this right?
I don’t see a belt near this size listed on the Corally site, is there one, or where are people getting these?
Thanks.
Thanks.
#3199
Thanks.
Thanks.
#3200
I´m not a team driver but have tested std vs. short wheelbase and dampers behind the tower back to back. Both indoors on carpet and outdoors on tarmac the shorter wheelbase setup is ap. 2/10 faster. The car rotates much faster without feeling lose and it has more steering. The std PHI have a very long wheelbase compared to other cars; actually the "super-short" wheelbase is very close to what Tamiya, Xray and others have from the box. Best to say that I´m driving modified rubber.
#3201
I'll upload my std wheelbase setup this weekend, it has a lot of steering and is also fast on the tighter shorter tracks. But still holds enough grip in the rear.
#3202
I done extensive testing with both and I've found the car is best on asphalt
(17.5/13.5) with the narrow steering blocks and super short wheelbase.
I do not run the 42T pullies so I dont know what belt you would use.
You can always call Corally USA and ask.
If you would like, I can post my rubber asphalt setup or send it too you.
Mike
Mike
#3203
Check out the photos of my Phi with super short wheel base at this link,
http://www.rctech.net/forum/5533118-post291.html
You need to use 36 tooth pulleys front and rear, use the standard front belt and a Tamiya MSX or 416 rear belt.
I have only raced it in mod and bitumen and found it to be very very good with good steering and exellent rear grip.
Rhys
Rhys
#3204
Rhys
Rhys
Thanks...
#3205
We race in two different locations, one with a 1425 gram weight limit and the other with a 1525 weight limit.
With the 1425 limit i was able to place some weights on the inside of the lipo tray, then when we do the 1525 limit i place some more weight on the outer side of the lipo itself.
When placing the weights on, i use balance pins to get the weight in the correct spots, you can get it to balance pretty good.
In the pic there are no weights placed on the car as it had just been rewirred and rebuilt, hope this helps.
Rhys
Rhys
#3206
Hi, I had a look at the pics of your car. May I ask how you get the weight of the car to be above the minimum required without any weights? and if you add weights where do you put them to get the car to be balanced correctly, side to side and cross weight?
Thanks...
Thanks...
FYI...At this year's IIC, Scotty has dropped the minimum weight for TC to 1425 gm. A very thoughtful move to accommodate our lipo setups. Hopefully, ROAR and other organizations will follow suit.
Bill
#3207
#3208
Rhys
Rhys
#3209
At the track, I use Irrgang Racing Balance Buttons for checking when adding minor amounts of weight. The buttons are much more accurate than old style balance pins.
Bill
