Team Corally RDX Phi >
Old 02-18-2009, 09:23 AM
  #3016
1rcracer's Avatar
Questions??
I need some help...
i need to raise the rollcenters on the normal phi bit higher than the std post and mounting allow ?
any tricks to do this.... we run foam on asphalt... i run also a diff in front.we have the car relatively good...
any help would be apreciated...
1rcracer is offline
Old 02-18-2009, 09:53 AM
  #3017
1rcracer's Avatar
Originally Posted by PHI/BMI racer
We never had problems with the duraluminum spool in 10.5 or higher motor classes. On rubber it was ok in mod too, but if you have a bad crash it can break or bend like any other part so keep it on the black stuff
Remember using a spool does wear out the front drive parts more then a diff. or one-way, so you need to make sure all parts are lubed and checked regularly.
Good Luck
Hey Vadaz when did u run a spool?
1rcracer is offline
Old 02-18-2009, 10:14 AM
  #3018
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by 1rcracer
I need some help...
Corally sells flat shims which are put under the block to raise it up.
MikeXray is offline
Old 02-18-2009, 10:37 AM
  #3019
BJohnson's Avatar
I need some help...
The RDX had ultra low roll center mounts. You could run those flipped upside down for extra height.
BJohnson is offline
Old 02-18-2009, 10:44 AM
  #3020
I ran a spool down in durbz to try it out a while ago.
Also why didn't you ask me at the track, I can show you how to change the roll center I got all the parts you need to make fine adjustments on it. If I see you at bedfordview I will show you, otherwise see you at the K90 nationals.
Caio
PHI/BMI racer is offline
Old 02-18-2009, 11:20 AM
  #3021
Trader Rating: 38 (100%+)
Originally Posted by aus jd 2703
hey guys im running the delrin spool and am chewing through a set of drive shaft clips every 3rd run there has to be a better way any ideas?
yes im a rather poor driver im not blaming the car, but i wanna address the problem.
You could try building a slipper spool. Basically a diff without the diff balls. The TC5 slipper pads might fit the diff to use in place of the metal diff rings. Or you can use those and just crank it down. Then when you hit it will just shift the diff rather then break the blades. I've used it in a TC5 and built one for a Tamiya car and it worked well in both.
or8ital is offline
Old 02-18-2009, 11:41 AM
  #3022
1rcracer's Avatar
Caio
Hey chap.... We tried all the tricks excep the shims under the mounting blocks...
Whats parts u got to change the roll center ? bring it to the track this weekend...
1rcracer is offline
Old 02-18-2009, 11:54 AM
  #3023
Sorry bud, I am in durban this weekend. Check your mail...
Old 02-18-2009, 12:15 PM
  #3024
E-clip's Avatar
Trader Rating: 39 (100%+)
Thanks Bill will try this soon
Originally Posted by Still Bill
E-clip,
I run the short wheelbase on my Phi everywhere...carpet and asphalt.
Parts needed:
Corally TC79670 Pulley 36 teeth for LW differential (rear)
Corally TC79671 Pulley 36 teeth for duraluminium spool / front 1-way
Tamiya TRF415 Low Friction Belt (Rear)
Use the standard Corally RDX Phi front belt with the above.
I also like the narrow steering blocks over the standard ones to gain more steering.
Bill
E-clip is offline
Old 02-18-2009, 09:38 PM
  #3025
Big Features's Avatar
Share Mike, share...
Bill
I'll post it tomorrow, no worries.
Mike
Big Features is offline
Old 02-20-2009, 03:36 AM
  #3026
sagejyoung's Avatar
hey megs, i'll look around for some roll center advice, i'm joinin the corally team this weekend for some race domination! hehe (
anyone wanna send me a corally shirt?
sagejyoung is offline
Old 02-20-2009, 04:34 AM
  #3027
Ah so RCracer is Megs, good to know finally. Sage, since when you got a corally? Good move though... I can show you all the roll center adjustments at the regionals.
Caio
Old 02-20-2009, 10:41 AM
  #3028
Yawwwww.. since when is Vadaz the master of Corally information ?..
and FYI, you can use shims / spacers under the suspension blocks to adjust the rollcenters more..
Dartanian is offline
Old 02-21-2009, 02:33 AM
  #3029
s.nicholson's Avatar
Good Luck
Hey i had no luck with the metal spool either it would snap on me where it has been lightened without even hitting anything.
s.nicholson is offline
Old 02-21-2009, 02:56 AM
  #3030
1rcracer's Avatar
Hey is this the s.nicholson that ran the corally at the worlds..
1rcracer is offline
