speed help
speed help
hey guys i need some help,, my car is going slow but it has good batts good motors bearings are new and the speedo is a v12 and a cyclone in my truck,,,but my car is going slow like i lend my good mods out and my freinds re flying past me and when there in my car there slow wats going on is it my speedy... one of the guys said it could be my radio iam using a KO ex1 mars r.
please help guys
thanx heeps
please help guys
thanx heeps
Check the motors, sounds like they need a comm cut and new brushes.
Radio? Check throttle EPA.
Also check the wiring and the transmission for any drag.
comm cut and skim, make sure your speedo isn't glowing!
also check its setup correctly.
sanj
sanj
hey wat should the throttle EPA be set up as
To get the best result, you should also go through the ESC setup again (after the EPA).
