what is the correct way to store battery?
Hi,
Can someone tell me what is the correct way to store battery. I was gone for 4 weeks and all of my battery false peaked and had to be recharged. I stored them at .9v.
for 1-2 weeks?
for 1 months?
for 6 months?
Thanks in advance.
for 1-2 weeks?
for 1 months?
for 6 months?
Thanks in advance.
what i do is after a run if i'm not going to use that pack till next week i discharge down to 0.9v let the pack cool down to room temp then put 500mah charge in them and store, then when i'm going to use them again i discharge down to 0.7v then peak as normal and run. Thats using ib42 wc's for gp 33/37's i only discharge down to 0.9. hope this helps.
Be extra careful with the 4200's. After talking with a few different battery matchers, the common concensus is that they have a tendency to reverse if not stored with enough charge for extended amounts of time. Typically, I'm putting 500 seconds back into cells that won't be used for more than 2 or 3 weeks and I haven't had any reversal problems. Just be sure to let them cool back down completely before charging again. Otherwise, you may wind up venting one. Hope that helps.
where to start?
Hey guys......I just purchased a used xray to start racing the touring class. I have a very small budget...until after christmas to get me started. The car came with six 3300 packs. The charger I bought charges at up to 5.0 amps. But discharging......I have no idea how to get the most out of these packs for now. Do I need a dishcharger? What would be the most cost effective way to keep these packs working for the next month until I can purchase what I need!!! Any help would be great R.
For a stick pack, its only reasonably convenient to discharge them in series down to 5.4 volts. You could probably get a bulb discharger and cuttoff bug for around $20.00, or fabricate something yourself with tailight bulbs and watch over it with a digital multimeter.
For a side by side pack you can discharge them in series down to 5.4 volts using the above method or a more expensive and higher amperage discharger then equalize them in a tray. You could get a used bulb type tray for around $20.00 and watch them carefully, or get a used Novak Smartray for around $50.00, it is better because it has automatic cuttoff on each cell.
