Old 11-26-2006, 07:31 AM   #1
thecrow2k's Avatar
Default Lathe Problems
I got a lathe about 2 months ago. The motor on it was a stock and ran fine, cuts were good with a diamond bit but being second hand, I wasnt sure how old the bit was.
I changed the motor onthe lathe to a tamiya silver can presuming this would run slower, smoother and last longer. However, the motor started to squeal alot recently, cuts were not as good (which I believe was the bit) and my Pulsar would say "CURRENT TOO HIGH" when trying to run the lathe.
Do you think its my motor thats the problem or what. Im looking at getting a carbide bit for the lathe and a silver can motor to stick on the lathe, think this will sort out my bad cuts?
thecrow2k is offline   Reply With Quote
Old 11-26-2006, 08:04 AM   #2
sosidge's Avatar
A squealing silver can is usually one that has worn the brushes out (it can happen after a LOT of use). Either that or there has been a motor failure of some sort.
A new drive motor should sort it out (run on 4.8V unless you use a specialist lathe motor). A new bit will give peace of mind but a machine tool specialist may be able to inspect/sharpen the diamond bit for you.
Old 11-26-2006, 08:39 AM   #3
Anthony.L's Avatar
Trader Rating: 36 (100%+)
FYI, spinning the slave motor slower will not give you a better cut or make your bit last longer. If you have a diamond bit and it's setup properly you would have to cut thousands of arms to wear it out, don't worry about that.
I spin my slave motor at 3.6 volts, or equivalant to a 3-cell battery pack.
Anthony.L is offline   Reply With Quote
Old 11-26-2006, 08:44 AM   #4
which model lathe do you have ?
is it spinning in the proper direction ?
what are you using for a cutting lubricant ?
Integy sells a 55t lathe motor. or put a armature from a stock motor in a mod motor can. but keep the brands the same. ex: epic stock to a epic mod can.
baih is offline   Reply With Quote
XIPP Super Lathe 3 / (pics) comm lathe diamond bit evostyle R/C Items: For Sale/Trade 8 12-01-2006 11:53 AM
Orion lathe problems FlyByWire Electric On-Road 27 07-31-2006 08:45 AM
Trinity Tru Lathe Setup Problems tminus3 Electric On-Road 27 04-05-2005 10:47 AM
problems with lathe quantum Electric On-Road 8 01-08-2004 07:43 PM
Fantom Lathe Problems yodace Electric On-Road 13 09-21-2003 01:55 PM
SEO by vBSEO 3.5.0
