High Grip Asphalt Setup for TC4
I run a FT TC4 at an indoor aspalt track. The track has a lot of grip and I was wondering if the carpet setup would be a good starting point. The track is about the size of a tennis court. Thanks.
Do you use rubber or foam tires? If it's rubber, go with this one...
http://www.rc10.com/racerhub/setup/r...yrace_2006.pdf |
