mounting electronics
could yall post some pics of yalls cars? preferably shaft drive cars. i cant find a good way to mount all my electronics directly on the chassis.
Why not tell us what kind of car you have that way someone with the same kind can post a picture for you.
really any sd car will be ok. i run a yokomo mr4tc-sd black special with a rayspeed chassis. its got a neo-one 4star on it and it has the lrp sphere comp and right now an airtonics 94102 servo. reciever is either going to be a novak XXtra synthisized or an airtonics 92926Z depending on space in the car
Here's my evo 5. I am using the KO low profile servo, it is sweet. I am also using hara twister 2.1 to go with that. There is actually extra space left. (but that's because my s4 capacitor is mounted under the shaft.
the neo-one is the same size as a normal moded or stock 540 motor. the sphere comp is a 33L X 38W X 15H mm case. the reciever will be either a 42L x 29W x 13H mm case or a 42L x 28W x 17H mm case
