Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-20-2009, 09:11 PM   #1456
liljohn1064's Avatar
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by 05tuonojoe View Post
I'm new and dumb when it comes to on road cars. Could someone give me a suggestion on pinion gear size to run? Track is small-med and i'm giong to be running the stock 98 spur gear for now. Motor is a 17.5 trinity duo brushless.
Try a 98/50.
USVTA Rules http://www.usvintagetransam.com/
MRT Personal Transponders http://www.rclaps.com/
USVTA - WGT - F1 - 17.5 Sedan/RCGT
Just race.
liljohn1064 is offline   Reply With Quote
Old 10-21-2009, 04:55 AM   #1457
The stock spur is too big for 17.5. Run a 78 spur. Your pinion will depend on the size of your tyre and what roll out you want.
R/C Rich is offline   Reply With Quote
Old 10-21-2009, 12:42 PM   #1458
05tuonojoe's Avatar
I'm coming from 1/8 scale. To tell the truth I have no idea what roll out is.
Team Terribles
Joe Wallace
Xray XB808
Novarossi +4
05tuonojoe is offline   Reply With Quote
Old 10-21-2009, 12:55 PM   #1459
CarbonJoe's Avatar
Rollout is the amount the car will move forward for one revolution of the motor shaft. Check out the spreadsheet I posted before for figuring out rollout easily.
http://www.rctech.net/forum/5250090-post30177.html
*** The Gate II - Where Talent Goes To Die ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Good judgment comes from experience, and a lot of that comes from bad judgment.
- Will Rogers
CarbonJoe is offline   Reply With Quote
Old 10-21-2009, 01:04 PM   #1460
05tuonojoe's Avatar
Windows wont let me open that for some reason. Just can't catch a break using vista I guess.
Team Terribles
Joe Wallace
Xray XB808
Novarossi +4
Old 10-21-2009, 08:43 PM   #1461
avs
ok try this one
http://www.rctech.net/forum/4792583-post5349.html
different link to the same target. i copied Joe's spreadsheet and made only two small changes, i 'painted' every fourth column and row grey for easier navigation, and added 2 columns that relate #teeth and diameter for spurs (i don't trust myself to recall what spur is installed). the only problem is that you need to print multiple copies for each spur size because people will ask you for one.
avs is offline   Reply With Quote
Old 10-31-2009, 04:27 PM   #1462
cheehtae's Avatar
Originally Posted by Stealth_RT View Post
My current GenX layout. Only part still missing is the TQ Booster, which is in transit from TQ Cells. Ran it once already, but had to use a rec. battery. Just finished re-doing the layout to shorten wires, remove the rec. batt, and fix up the ride heights and make a special change to the rear suspension.
notice your long arm, what's the difference between the short and long arm?
tnx
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Forum Jump
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 05:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 05:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 05:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 03:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 03:22 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
