Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-15-2008, 04:04 PM   #1381
Ty
Ty's Avatar
Trader Rating: 14 (100%+)
Can't wait to get my GenX this week. Thanks to the guys at CRC in Rome, NY and McSmooth here locally in Pittsburgh for all the help.
www.supplementcentral.com
Ty is offline   Reply With Quote
Old 11-13-2008, 08:49 PM   #1382
R.Dalnogare's Avatar
Send a message via AIM to R.Dalnogare
Bump...
I'm sure this has been asked a million times, but does anyone have the part numbers for the Xray (I believe its an Xray part) ball cup you can out on the CRC shock that lets you use a hex wrench? If that made any sense.
Also, and word on the new "Encore" shock?
Ryan Dalnogare
EA Motorspots-ParmaPSE-Faskolor-Exotek-Psycho Cells
R.Dalnogare is offline   Reply With Quote
Old 11-16-2008, 01:02 AM   #1383
bboy's Avatar
Has anyone tried the Brushless Offset Rear Pod Conversion #3349?
Can I just get the off set rear hubs and reuse the existing parts?
Any feedback?
Cheers.
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
CRC Gen-X + Novak Brushless 4.5
bboy is offline   Reply With Quote
Old 11-16-2008, 06:07 AM   #1384
bboy,
You need the whole conversion. My car felt tweaked with brushless until I installed the new pod. Without the conversion there is too much weight on the left rear tire, which can cause inconsistent handling.
James
Yankey is offline   Reply With Quote
Old 11-16-2008, 02:02 PM   #1385
joey's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to joey
Originally Posted by R.Dalnogare View Post
Bump...
heres the parts ryan,
http://www.nexusracing.com/product_i...roducts_id=469
http://www.nexusracing.com/product_i...roducts_id=220
=Majs Hobby Shop=
-Joe Wright-
joey is offline   Reply With Quote
Old 11-16-2008, 02:35 PM   #1386
Originally Posted by Yankey View Post
bboy,
James
Can you give more detail why you need the whole conversion. In the description of the convertion kit it says (individual graphite pieces are straight off the Gen-X 10 - P/N's 1765, 1766, & 1774). It reads like you would just need the hub.
rushrush1 is offline   Reply With Quote
Old 11-16-2008, 05:39 PM   #1387
buffalobill989's Avatar
Trader Rating: 33 (100%+)
from what i have been able to tell you can buy the whole kit which is the graphite and the hub for 49.99. i just ordered it and i think all i need is the open left pod and im all good. im anxiouos to try it out
buffalobill989 is offline   Reply With Quote
Old 11-16-2008, 05:46 PM   #1388
The BL motor pod for the 1/12 gen-x shifts the motor .15" or so to the diff side of the pod. The upper, lower, and x-brace graphite pieces are .15" wider than the original gen-x (These pieces are used on the gen-x10). Also, the diff hub needs to be .15" narrower to take up the difference.
I think the conversion assumes you are already running the open-x pod so you would already have the correct lh pod plate and aluminum standoff. If not you would need to order those parts as well.
James
Old 11-16-2008, 08:09 PM   #1389
sweet thanks for the info
Old 11-19-2008, 06:53 PM   #1390
gijoe64's Avatar
Hey guys Im thinking of putting the long ball suspension on my Gen-X what affect does it have on the handeling of the car? Also I will be running 17.5 at the Snow birds what type of gearing will I need?
http://www.muchmoreusa.com/
http://www.teamcheckpoint.com/
http://2.4gigahertz.com/
gijoe64 is offline   Reply With Quote
Old 11-19-2008, 07:45 PM   #1391
Victor Vector's Avatar
Bump...
I use the X Ray bottom shock mount. With a 3mm screw glued in from under the top plate. Just have to file a bevel on the front top edge in order to gain full travel. If you don't file the plate you will have occasional strange things happen (like rear ending) that will pop the plastic off the metal ball end.
I put the b/less pod on my Gen X and it became a race car again !! Great change up.......
Jacko
ROAR 11-103837 MUB AY PU
Corrally, CRC, Mugen MTX4r, MYKART Artwork,
Rose City Scale Racing, Hanger 30, IBEW Local 48
RITCHIE REYNOLDS FOR REGION 11 DIRECTOR!!!
Victor Vector is offline   Reply With Quote
Old 11-19-2008, 07:53 PM   #1392
The long ball front end slows camber gain, which reduces steering. If you have too much steering and can't take enough out of the regular front end give it a try.
James
Old 11-20-2008, 07:48 AM   #1393
gijoe64's Avatar
what is a good start for 17.5 spur/pinion? This will be for the SNowbirds?
Old 11-27-2008, 08:21 AM   #1394
Default want to green
hi guys, i,m fed-up with nitro prices ,but i still need my r/c fix.. how well is this (gen x) car supported on the west coast (ca.) have been driving 1/10--- 1/8 on road ,but now want to try my hand at 1/12 pan. we don't have carpet tracks in los angeles just outdoor asphalt. would this car work ? are there lhs in cali. that support this product.
isuzuguy is offline   Reply With Quote
Old 11-27-2008, 09:29 AM   #1395
espresso1967's Avatar
I run the Gen X 10 pan at Crystal Park in Compton. Not often but when I have a chance. I run a a 3.5r novak, runs very well among nitros. Crystal Park is an all nitro track but on practice days you can run with the nitro guys. Been busy the last two months and have not been able to run but hopefully in the coming weeks I can get back out there. I would not recommend a 1/12 at this track. There is an all electric track in Orange that does 1/10 electrics and on occasion 1/12 indoor carpet when available. You can find more info here http://www.rctech.net/forum/racing-f...lt-we-got.html
If you have any questions about the two tracks personal message me if you have any questions.
Here is a youtube I took of Bending corners and Crystal Park.
http://www.youtube.com/watch?v=6JrpRM5TY54
Crystal park different angles of the track so go through fast forward if needed
http://www.youtube.com/watch?v=R0NUf_ttLxM
Calandra CRC Gen X 10 - TC5R
espresso1967 is offline   Reply With Quote
Forum Jump
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 05:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 05:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 05:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 03:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 03:22 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
