Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-09-2008, 09:01 PM   #1336
Brian
Mark
Max
Chuck
Terry
and who ever else made the mains at the Nats could you please take a minute and post your set-ups?
This is a big help to us slow guys.
march to my own is offline   Reply With Quote
Old 05-09-2008, 09:12 PM   #1337
Originally Posted by march to my own View Post
Brian
Mark
Max
Chuck
Terry
I am on it.... sorry guys, Gen-X 10 is keeping us busy. Should be up soon.
Team CRC is offline   Reply With Quote
Old 05-10-2008, 03:42 AM   #1338
Originally Posted by mhkang View Post
Was reading that team CRC in Japan came out with a modified chassis for asphalt racing. Anyone in the states get it? Looking for a review of it.
Some googled links to get information about the J-Spec:
http://www.teamcrc.com/crc/modules.p...ewtopic&p=8862
http://www.petitrc.com/_forumphp//sh...ad.php?t=33151
http://www.petitrc.com/reglages/crc/...ec/Article.htm
http://www.kimihiko-yano.net/weblog/...es/004265.html
Arn0 is offline   Reply With Quote
Old 05-13-2008, 05:05 AM   #1339
Genx-10 shipment sold out on stormer already! that was quick
Good thing i get in there while stock was available
these things are hotter than hot cakes
RCRacer.co.nz - New Zealand RC - news - videos - photos
drivingpro is offline   Reply With Quote
Old 05-13-2008, 06:06 AM   #1340
stanislow's Avatar
Send a message via MSN to stanislow
best thing IMO is how easy it was to build. it basically fell together!
Shockwave Motor tuning,
Team Mad Scientist
Eastridge Hobbies
RC Canwest Xray Jaco SMC
stanislow is offline   Reply With Quote
Old 05-13-2008, 04:26 PM   #1341
haddow's Avatar
Brian
Mark
Max
Chuck
Terry
Hello guys
here is the first setup. This is the ROAR Nats winning Stock setup from Brian Wynn. It is posted in the Tech section at teamcrc.com, view it direct with this link:
http://www.teamcrc.com/crc/downloads...Wnatssetup.pdf
haddow is offline   Reply With Quote
Old 05-14-2008, 10:23 AM   #1342
Originally Posted by haddow View Post
Hello guys
I noticed this setup does not use the Long Ball Front Arm setup, correct?
www.readytorunrc.com | www.rtrrc.com | www.mikeshobbyshop.com
Kelly Nowell
kn7671 is offline   Reply With Quote
Old 05-17-2008, 07:59 AM   #1343
That is correct. I did not use the long ball setup.
www.teamcrc.com, advanced electronics, www.teampowerpush.com, www.crcraceway.com, www.spektrumrc.com, www.dynamiterc.com, dumper's speedshop. moby graphics, G2 Designs - Check them out in the painting thread!
***2008 ROAR 1/12th Scale Stock National Champion*** Now what were the odds on that in Vegas? 38.4mm>38mm end of story.
dumper is offline   Reply With Quote
Old 05-31-2008, 09:14 PM   #1344
bsmooth's Avatar
..Could any of you guys post an asphalt setup for 19t? I can only find carpet setups on the CRC website.
Muchos Gracias.
-Steve
bsmooth is offline   Reply With Quote
Old 06-01-2008, 05:02 PM   #1345
SRW141's Avatar
Muchos Gracias.
-Steve
Front:
5 blocks
1 shim front/ 2 back
4mm ride height
170mm front width
crc magenta tires/ paragon on 1/4" of inside of tire
#4 wind tunnel lube on king pin/ .50mm front spring
-1 toe out
-1 camber
Rear:
shock 30 wt oil w/ silver spring
white side spring
4mm ride height/ front and rear of pod
crc pink tires
172mm rear width
#4 wind tunnel lube in tubes
tall crc red ball stud on top of shock
tall crc red ball stud w/ 1mm shim, lower mount for shock
Paragon traction compound/ full/ put on for 30 minutes/ apply twice during this time.
Steve Walter
Team Driver For: Schumacher USA/ eXpress Motorsports
Karens Famous Cookies (Transporter),D&K Air Designs
"The Track"/ "The C"/ 301 Raceway
SRW141 is offline   Reply With Quote
Old 06-01-2008, 10:09 PM   #1346
bsmooth's Avatar
Originally Posted by SRW141 View Post
Front:
5 blocks
4mm ride height
170mm front width
-1 toe out
-1 camber
Rear:
white side spring
crc pink tires
172mm rear width
Thanks Steve!
Are you using CRC Pro-Cuts?
Old 06-02-2008, 05:55 AM   #1347
SRW141's Avatar
Thanks Steve!
Yes.
Steve Walter
Old 06-02-2008, 06:54 PM   #1348
bsmooth's Avatar
Yes.
Thank you.
Old 07-26-2008, 05:54 AM   #1349
bboy's Avatar
I am new to 1/12 and just got the carpet knife and have 2 questions:
1) it looks like I need to remove the shock everytime I change battery, is this the case for by design? Seems odd since I am worried about the wear on the cup.
2) how do you layout the electronics. I am running brushless and am not sure the best way to organize the wires etc.
Help ...
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
CRC Gen-X + Novak Brushless 4.5
bboy is offline   Reply With Quote
Old 07-26-2008, 11:05 AM   #1350
odpurple's Avatar
Help ...
Yes, you have to pop the shock off on one end to install the batteries. If the ball cup eventually gets loose just replace it.
Here is one way to wire the car:
odpurple is offline   Reply With Quote
Forum Jump
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 05:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 05:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 05:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 03:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 03:22 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
