Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 12-13-2007, 07:50 PM   #1201
skypilot's Avatar
i just purchased a brand new gen x last weekend, while trying to fit the right rear wheel bearings on i had a heck of a time, upon inspection i found that the axle has a crack in it and is ever so slightly over size where the threads were inserted, is this going to be a problem?
skypilot is offline   Reply With Quote
Old 12-13-2007, 09:29 PM   #1202
odpurple's Avatar
If you mean the axle has a crack where the stud for the diff nut goes, it may not be a problem right away but it could weaken and pull the stud out later. You should send the axle in for a replacement. Don't worry, CRC stands behind their products 100%.
odpurple is offline   Reply With Quote
Old 12-13-2007, 10:03 PM   #1203
bsmooth's Avatar
What gauge wire are you guys using to wire your speedos and motors (brushed)?
Is there a way to use the heavier wire without binding up the chassis?
The small gauge stuff looks so weak!
Thanks for all of the help.
-Steve
bsmooth is offline   Reply With Quote
Old 12-13-2007, 11:36 PM   #1204
wallyedmonds's Avatar
-Steve
you only need 18G for 1/12
16 is ok bigger is just a waist.
brushed or BL
/RB-5/LRP SPHERE/CRC-GEN-X/NOVAK 10.5/SMC/PARMA BODY'S/LOSI 8 2.0/GRP 21 BUGGY TUNED/OS/
FROM BRAMPTON ONT CANADA.
WWW.FASTCATS.CA
the red dot sucks, there i said it
wallyedmonds is offline   Reply With Quote
Old 12-14-2007, 05:41 AM   #1205
SRW141's Avatar
Sorry Frank. Jack told me he made them for you.
Originally Posted by Team CRC View Post
Just a quick correction here...
Jaco does not make the foam for CRC tires. In fact, I'm very sure that Jaco does not make the foam for Jaco tires. CRC, GRP, Parma, BSR and Jaco all get foam that originates from the same factory in Japan.
CRC pioneered the big wheel craze that has now been "implemented" by every other manufacturer. Our Pro Cuts have won Regional, National and World Championships.
When comparing to other brands, CRC front wheels have a slightly larger OD. It also appears that our wheels are a bit more stiff than the rest. Another nice feature is the design of he rear wheel puts additional bracing around the mounting area. We like to think that this design allows our rear wheels take hit better than other wheels.
With our new, more efficient mounting and truing, a few months ago, CRC drastically lowered the price of the tires to distributors allowing them to sell to the dealers cheaper. We hope that dealers pass this savings on to the final consumer. As tires stock moves through the system, we are beginning to see prices on the Pro Cuts drop to the sub $12 range.
Best tires, great price. But of course I am biased!
Thanks,
Frank
Steve Walter
Team Driver For: Schumacher USA/ eXpress Motorsports
Karens Famous Cookies (Transporter),D&K Air Designs
"The Track"/ "The C"/ 301 Raceway
SRW141 is offline   Reply With Quote
Old 12-14-2007, 09:18 AM   #1206
No problem, thanks for support. We appreciate it.
Team CRC is offline   Reply With Quote
Old 12-14-2007, 05:45 PM   #1207
skypilot's Avatar
thanks for responding, OD, umm probably met you at nats, i'm a friend of Jb's
Old 12-14-2007, 06:49 PM   #1208
odpurple's Avatar
any friend of Mr. Bee.....
Old 12-15-2007, 08:55 AM   #1209
I just got to say that the more I drive this car the more I like it. Well, I think it is a 1/12th scale thing in general, but this just happens to be the car I am driving. I do have a few questions; my rollout is 40.88mm, tight tech track (40'x60'), Co27 motor comes off the track at 145 F. Good, not good? I am also having problems with the diff, it seems to pick up a lot of carpet and get inside the diff rings sometimes requires a rebuild before the main, but it is something I am doing as others are not having the same problem. Are ceramic diff balls worth it?
trilerian is offline   Reply With Quote
Old 12-15-2007, 10:28 AM   #1210
ceramic balls are good
and you only need a little pit of lub on the balls,dont over do it.
WWW.FASTCATS.CA
Old 12-15-2007, 11:09 AM   #1211
Maybell's Avatar
you said "lube on da balls"
Sean Maybell
Team Associated - High Velocity - JConcepts - LRP - Reedy - Factory Team - XP Digital - PPD Billet - Remote Control Hobbies
Maybell is online now   Reply With Quote
Old 12-15-2007, 01:10 PM   #1212
aaron_buran's Avatar
Where do you get the ceramic balls from? In Mod, I am having to rebuild it every 3-4 runs, I think it's the rings. I can just flip the rings over, and it's good again... In 19T and stock the kit rings/balls hold up just fine. Any input would be appreciated.
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 12-15-2007, 01:15 PM   #1213
jbsmith1's Avatar
If you use Kimbrough spur gears, they do diff covers for them...
crcs-new-generation-x-your-thoughts-th_on_road_racing_64no2.jpg   crcs-new-generation-x-your-thoughts-th_kimc1140.jpg
jbsmith1 is offline   Reply With Quote
Old 12-15-2007, 02:48 PM   #1214
jarkkom's Avatar
Send a message via MSN to jarkkom
Get a http://www.slapmastertools.com/101-1...iff-thrust.php and your diff lasts a while even with the carbide balls.
medasec.fi | racingfactory.fi | v-dezign.net
jarkkom is offline   Reply With Quote
Old 12-15-2007, 05:55 PM   #1215
Maybell's Avatar
you can get high end cermamicz from Team Axiom...
Sean Maybell
Forum Jump
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 05:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 05:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 05:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 03:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 03:22 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
