CRC's New Generation-X.... Your Thoughts?
#1021
#1022
#1024
I prefer the foam ones like the Slapmaster, Parma, etc. The Kydex certainly protects but it aborbs little or none of the impact, transmitting it directly to the screws. In a big hit (and, admittedly, BIG hits) I've seen the kydex bumper lever the screws through the chassis. The foam bumpers absorb impacts, though a BIG impact could still bring the chassis plate into contact with a barrier, etc and cause chipping or some such. Chipping doesn't usually impact utility of the chassis like screws pulled through does.
Scottrik
Scottrik
#1025
i like the Slapmaster bumper,works great.
#1026
Scottrik
Scottrik
Also, I'm running IB4200's. Is there a trick to getting those into the battery tray without disassemblying anything? The picture on the CRC website shows it fitting without a jumper wire. I'm thinking I may have to split the pack and run a jumper wire.
Last, is there a site that explains what rollout is and how we calculate it for 12th scale cars?
Thanks a million for everyones help!
-Steve
#1027
bsmooth: you gotta pop the shock...
Rollout is the distance the car moves with one rotation of the motor.
Rollout = (pinion/spur)*pi*tire diameter
The attached excel file works for brushed motors. We print them out on 11x17paper and get them laminated. Works great.
James
James
#1028
could you update the rollout to go up to 47 tooth pinion and include a 74,76,78 spur.
I have a 17.5 and would to know the rollout without having to calculate. thanks
#1029
cookie1: attached is the brushless edition you asked for...
#1031
yes it will wear. I usually add a o-ring or cut a small pcs. of fuel line to take up slop. Yes there is a very special tool I use. Needlenosie pliers.
Yankee- you are very smart. Where do you race?
Thanks for gear chart!!
#1032
Yep. Needlenose. Just be careful not to bend the end of the shock body. Use the o-rings and replace the cup every once in awhile. You can do this too: http://www.teamcrc.com/crc/modules.p...ewtopic&t=1747
Cookie, I race in West Michigan. You?
#1034
I race at the Gate in Cleveland. You coming to the classic?
#1035
http://i24.photobucket.com/albums/c2...Picture024.jpg
http://i24.photobucket.com/albums/c2...Picture014.jpg
http://i24.photobucket.com/albums/c2...Picture015.jpg
HTH
ah, i just see some one linked it,cheers Yankey.
