Old 10-23-2006, 10:35 PM   #1
Default Novak cooling fan how do I wire it?
Hi I bought a Novak 25x25x10mm 5647 fan for my car to use to cool my motor. What do I conect the wires to. the fan is a 5vdc fan so can I connect it to a 7.2 volt battery pack with out buring it up?.if not what do I connect it to? Thanks.
Philip Henzog is offline   Reply With Quote
Old 10-23-2006, 10:45 PM   #2
hook it to ur reciever open channel or batt plug itll b fine
LAPDOG is offline   Reply With Quote
Old 10-23-2006, 10:46 PM   #3
You can connect it to the reciever 3 channel or the reciever battery slot....
Whether the fan can withstand a 7.2 volts really depends of the quility of the fan. Good ones can withstand 7.2V but not the lousier ones. I had one that I connect to 7.2 V and it burned up about a few packs. Then I replace it with a another one with the same dimension different brand and its still kicking after so long!!
I guess Novak's would have found themselves with a good fan manufacturer for them to put their good name on!
Ben.C is offline   Reply With Quote
Old 10-23-2006, 11:30 PM   #4
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
solder it to your esc wire (b- and b+) b mean battery wire the red and the black one. just make a connection or just cut a little hole on the wire and solder the wire from the cooling fan to the wire of the esc.
pinggoy is offline   Reply With Quote
attention anyone who has broken a novak sensor wire BSS07 Electric Off-Road 1 07-11-2008 09:52 PM
Novak sensor wire Kane-o Electric Off-Road 1 05-19-2008 09:16 PM
Novak Sensor Wire GymBeam Australia Wanted to Buy 0 03-26-2007 05:10 AM
NOVAK SS+ESC & 5800 & Upgrade Kit w/wire set runaway R/C Items: For Sale/Trade 2 02-09-2007 05:15 PM
Wire length of the NoVak GTB Bigedmond Electric Off-Road 5 01-30-2006 04:06 PM
SEO by vBSEO 3.5.0
