Old 10-23-2006, 04:55 PM   #1
imjonah's Avatar
Default Cleaning Foam tires run on carpet
One thing I don't like about carpet racing with foam tires is all the traction compound gunky residue and carpet fibers that the tires pick up during a race.
also an associated problem with a kind of slick shellac like coating I get on the tires some of the time. (I was told that this comes from overheating the tires and it is melted traction compound)
I have read people recommending motor spray to clean tires or actually soaking them in the traction compound it self.
Might the slick shellac like coating also be caused by using too much traction compound or not wiping enough of it off before race.
Is their any special procedure you do with your tires during the week to deep clean them or in other ways prepare them?
imjonah is offline   Reply With Quote
Old 10-23-2006, 05:01 PM   #2
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
when the traction gets high emough to cause the symptoms you're describing lots of racers will alternate between sets of tires. After a round they will scrub them clean with motor spray and a terry towel or rag and then let them sit. Could be other ways to do this but A. This one works and B. Its been like 9 months since we've had that kind of traction at my track.
|◤ReflexRacing.net◢|◤Gravity R/C◢|◤HWNA◢|◤AVID R/C◢|
Old 10-23-2006, 05:42 PM   #3
RaceAce701's Avatar
Trader Rating: 82 (99%+)
i scrub the tires with oops and a paprer towel after every run and befor i leave the track
works just as good as motor spray
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 10-23-2006, 05:44 PM   #4
Chris08527's Avatar
Trader Rating: 16 (100%+)
robinson lighter fluid in the yellow bottle works really well . .
as soon as you come off the track put it on then wipe it off with a rag
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 10-23-2006, 05:49 PM   #5
GrandeGixxer's Avatar
Zippo lighter fluid works just as well. I get it for like $1 per bottle. Lasts quite a while.
GrandeGixxer is offline   Reply With Quote
Old 10-24-2006, 04:05 AM   #6
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Blue painters tape works very well; and with no checmicals used, less of a chance to damage the tires.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 10-24-2006, 12:26 PM   #7
imjonah's Avatar
Default Thank You
I am still not clear what causes the slick shiny coating, is it melted traction compound.
Will cleaning with solvents like lighter fluid or motor spray adversly effect the foam over time and/or for the next race?
Old 10-24-2006, 01:35 PM   #8
timmay70's Avatar
I like to use motor spray. Just spray it on and wipe it off. I use either terry rags or Scott blue shop towels. This build-up is usually caused by the rubber laid down in the groove getting caked on the tires. Some traction compounds (Jack) cause it more than others. We don't have enough on our track to cause this problem... yet.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
WTB: 2.2 Foam Tires for racing on Carpet Associated-08 R/C Items: Wanted to Buy 6 03-04-2008 07:14 PM
Foam tires on carpet -why harder compounds? Iceracer Electric On-Road 9 01-12-2007 10:58 PM
FS:JACO CARPET FOAM TIRES!!!! NIB cornerspeed R/C Items: For Sale/Trade 17 11-01-2006 07:51 PM
PARMA foam carpet tires- NIB BigDogRacing R/C Items: For Sale/Trade 21 03-04-2006 11:54 AM
tires for carpet rubber vs foam sportracer Electric On-Road 6 01-21-2003 08:06 PM
SEO by vBSEO 3.5.0
