Old 10-17-2006, 12:23 PM   #1
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Default Schottky Rectifier = Shottky Diode?
Just found this at a local electronic component shop..
http://www.ortodoxism.ro/datasheets/...or/mXrtsvs.pdf
MBR3045PT, Schottky Rectifier, 30A, 45V.. this will work the same as the usual cylinder-shaped ones, just chop one leg off, correct? They don't seem to have any schottkys (MBRxxxx) above 3A that come in that package type.. I just want to make sure they'll do the same job.
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 10-17-2006, 12:50 PM   #2
asw7576's Avatar
Yes, it is actually ultra fast switching schottky diode rated up to 30A @ 45V. It is better spec than the cylindrical ones ( read : overkill ).
If you chop one leg, the amp is reduce to 15A.
Once I use SBL3040 for QC2 and V7.1
Actually I get no effect at all ( no performance loss or gain ) ..... it just more weight, more cables and more headche.
Now I keep everything simple and yet I'm still getting no performance loss or gain without schottky. One thing I know my life become easier, and my cars look neat and tidy.
Old 10-18-2006, 07:37 AM   #3
Iceracer's Avatar
Don't chop off a leg. You had might as well use both diodes if you are carrying the weight. Just connect pins 1 & 3 together and you have two diodes in parallel. As previously mentioned, two diodes in parallel make for double the current carrying capability.
Iceracer is offline   Reply With Quote
Schottky Diode?? aus jd 2703 Electric On-Road 38 06-30-2006 02:14 AM
Schottky diode? 4ou Rookie Zone 6 08-27-2005 02:28 PM
Schottky diode for ESC danjoy25 Australian Racing 13 07-13-2005 11:12 PM
Shottky diode, what kind? Cylindrical... mxs Electric On-Road 5 08-26-2004 07:22 AM
Shottky Diode StewartFan20 Rookie Zone 1 05-28-2004 06:44 AM
