Old 10-15-2006, 04:28 AM   #1
Nautilian's Avatar
Default How do you clean your carbon fibre?
Hey there guys,
So I am in the process of rebuilding my TRF, but I have a bunch of scratches on my bottom deck that I would really like to get rid of and at the same time look after the carbon fibre, does anybody have any suggestions other that soap and water for cleaning off the dirt?
Nautilian is offline   Reply With Quote
Old 10-15-2006, 07:05 AM   #2
Anthony.L's Avatar
Trader Rating: 36 (100%+)
CA, wet sand, and polish.
Anthony.L is offline   Reply With Quote
Old 10-15-2006, 07:10 AM   #3
Nautilian's Avatar
What gritt wet sandpaper and what sort of polish?
Old 10-15-2006, 07:11 AM   #4
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I think he was refering to the marks on the bottom of the chassis...
I use this stuff called Goo Gone, found in the paint department of any Walmart,
It gets rid of almost anything if you let it set on the problem area for a bit.
Then just rub off. If it is a persistant issue, I would use a scrubbing pad that isn't abrasive, like the plastic ones on kitchen spounges, they seem to work well. Just don't be too rough..
409 is also a really good degreaser.
Hope that helps,
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-17-2006, 11:10 AM   #5
mfishel's Avatar
The super-glue is a great idea. I haven't tried it, but I think I see where it could rejunenate the part as well as extend it's life.
First clean the part thoroughly. I think Goo Gone would work very well. However it leaves a lot of residue, so once you're done with that clean again with rubbing alcohol. Make sure their is no grease or residue AT ALL.
Now comes the super-glue. As I said, I haven't done this, but do use it on all edges after sanding to eliminate delaminating. I think the same basic concept applies here.
Once the part is cleaned and dried, lay it horizontal and fill the gouges with super-glue. Don't use more than you need, then allow to settle in and dry. If you still notice troughs after drying you can add more. Try avoiding creating any hi spots to avoid having to sand.
Now the final step is polishing. You may be able to use a good quality chrome polish, but I'm not sure. Definately use a soft cloth to apply, and maybe a good quality automotive finishing polish would be better. Test a scrap piece or a spot that isn't visible and see how it comes out.
Once you're done I suspect that you're going to have a part that looks good as new and is more resistant to further scratching.
mfishel is offline   Reply With Quote
Old 10-17-2006, 11:25 AM   #6
Speedie's Avatar
I use mothers chrome polish for cars to polish cf. It works great. I use very fine steel wool instead of sandpaper to smooth out the glue also works well.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 10-17-2006, 11:30 AM   #7
Send a message via AIM to Justin Zorc
if im after a polished look on my carbon fiber, i scuff it with a carborundum grey final prep pad (similar to scotch brite pad) and spray it with automotive clear coat. not only does this protect the carbon fiber, but it can be buffed if it gets scratched, and anso makes it slightly stiffer.
Justin Zorc is offline   Reply With Quote
MY NEW CARBON FIBRE TT-01 32819toon Electric On-Road 58 08-01-2008 04:18 AM
carbon fibre effect myk505 Australian Racing 7 10-18-2006 08:07 AM
M18 Carbon Fibre yop deck Dialed Pile R/C Items: Wanted to Buy 2 09-24-2006 06:22 PM
Sealing Carbon Fibre DA_cookie_monst Electric On-Road 13 08-13-2006 10:53 AM
Fibre-lyte carbon fibre 12th scale ride height spacers BritRacer R/C Items: For Sale/Trade 28 04-14-2006 06:02 AM
SEO by vBSEO 3.5.0
