TRF414M2 belt
TRF414M2 belt
Does anybody know which belt the TRF414M2 uses? the 415 belts or the TA04 belts? i can't find any belts specifically made for the M2. and another thing where can i find a belt stabilizer like this one.
The TA04 and 414 front belt are the same (low friction version is P/N 53463). The rear belt for the 414 is specific to the 414 only, P/N 6244004. As for the tensioner, I believe it was just two of the flanged steering bearings or 1 flanged bearing and a washer screwed into a standard plastic steering servo mount. To "adjust" tension, you add washers under the plastic piece to raise.
The front belt's on sale for ebay. I'm having trouble locating the rear belt. On the tamiyausa's website, it says that it has been discontinued. Know where i can find one? Thanks
the 415 rear belt should fit... i have a 414 belt on the rear of one of my 415s, after not having a spare. the 414 belt is lots wider, but works fine.
the 414 belt is still available... it says to order the 53464.
http://www.tamiyausa.com/product/rcp...ion=&offset=61
i think they just did away with the older #...
