corrally connectors
#16
Originally Posted by JayL
I've been using corrally bars forever and mostly in off-road..no issues, solder like Harsh's pic...If you think they'd ever come out, they won't, just put a screw in them then they can't..the inner connector has a thread on the bottom you can screw into after you insert into larger barrel...
Harsh: ahah! you went back to a battery brace!!! we are taking back the secret handshake.
#17
How do you go about soldering the connectors directly to the battery without overheating them. I have found that you have to get the connectors very hot and am worried about killing my cells.
#18
Originally Posted by HarshGuy
Na ...that's the only good picture I have of the plugs and connectors ....I''m using tape, no way I would want to risk tearing that battery brace out of the chassis ...here's a current pic, but you can't really see the battery connectors that well:
#19
i was about to ask that to.
#20
pre tin the connector before you solder it to the pack
#21
Originally Posted by RussB
daaaaaaaaaaaaaaaaaamn! since when was 8 degrees rear toe-in the hot setup?
#23
I think it's the camera angle or something, the car doesn't have as much rear or front toe as it looks like in that picture ...but even if it does, it is setup enough to kick your sorry a$$ every time we've met out at the track
btw, it's because you used a wide angle lense.
#24
you solder the tube on the battery the same way you solder a bar to the battery...always works for me...
or try the new much more magnetic holders for soldering
#25
There is a thread on JRXS.com that I contributed a a write-up on installing them on a JRXS for easiest use. I use them on every car i have now, except 12th scale, and I have found them to be a fantastic connector. They are resold by Trinity, Orion and others, too, if you can't find the Corally ones. They are all the same type of connector.
I'm waiting for motor companies to use this type of female connectors on endbells for easy (solderless) motor connections, too. Checkpoint, are you guys listening??
#27
Originally Posted by tmaxxking
nice set up for sure
i want to try it out on my carpet knife to
thanks again
thanks again
#29
#30
Integy A
Integy B
