Step-charging - is it necessary?
I know this has probably been asked, but is step-charging really necessary? I mean, is there a real performance difference? Or it does matter even if it shortens the life of the battery since there will surely be new batteries coming out within 2 or 3 months. Danny of SMC says to use linear charging with no mention of step-charging. Any comments??
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
I went for the `flavour of the month` method
i now just use linnear @6 amp that`s it
I noticed a slightly higher voltage bt a slighty lower mAh charge when I did step charging. I think that mainly came because of how it was set up. I had my charger to charge to the same spec as Atsushi Hara with his packs.
I really don't think it matter's either way so I don't know if I'll continue to do it or not.
Thanks, you three. It pretty much confirms my reasoning.
We do see linear charging get more performance from the pack, while 3 step charging (low amps charge at the very beginning, high amps at the middle range and low amps at the end of charging) will be more ease for the packs.
For practice, we would suggest to use 3 step charging so you'll have extended battery life.
For competition, linear charging will be suggested.
No matter what, please use as low peak detect as possible (just setup a bit higher peak detect before false peak)
