Old 10-02-2006, 09:43 AM   #1
Default Please, some tips.....
Hello Folks....
First, here some pics of the race of yesterday....
More photoshttp://www.minimania.org/rc/fotos/01102006/ http://www.minimania.org/rc/fotos/01102006/
The race are with stock motors, and I have a 27T Monster Pro.
Well, please I need tips, for set-up my car.
First Problem:
Shocks Set-up:
The settings are.
Tamiya Super Low Friction Dampener TA03 - 53280
Front: Oil 30 - 2 holes - blue springs
Rear: Oil 30 - 3 holes - factory springs
Second Problem:
I set-up the Front-End Alignment , but after walking 800 meters, the car begins to go for the right or left , and it is very difficult correct the alignment on race.
I have a servo futaba S9001.
third problem ,
which is the best bursh for this motor? , all brushess are legal on our group.
Yesterday some guy with the same motor was + / - 3.000 rpm more, and I don`t know why!!! $ˇ%"ˇ$%ˇ$%"ˇ$%.....
That´s All...
cuesco is offline   Reply With Quote
Old 10-04-2006, 09:16 AM   #2
juantrinidad's Avatar
1st correct the tracking problem.
The tamiya mini car can do the following things.
- at high speed, the rubber tires can ballon and catch the polycarb body.
solution - cut the body around tires. not pretty but you need to.
- over tightening the tire nut can cause the tire to bind. this cause the car steer to one side. check and correct each tire nut.
- glitching of motor can cause servo to react at high speed. make sure you have enough caps on motor. SMD caps in newer motors do not seem to do as good a job as big ass regular capacitors.
- soft brush springs can cause major glitches due to brush jumping. run motor out of car and make sure you dont have lotsa arcing/flashing. make sure you have proper motor brush.
2nd shocks/suspension
- I suggest you get the tamiya sway bars. They help a lot.
- I cannot help you with shock set up. It all depends on your track. Ask your fellow racer what they do. I like to put a stiff spring with a slow rebound. I Usually use 40-60 weight.
3rd Best brush
As always, high silver content is best. And so is soft brush. But both do not come together always. Depends whats available in your area. Buy racing silver brushes from a good company in your local hobby shop. Makes sure you break-in properly. Clean comms after each race. If you have a comm lathe, cut comm lightly after each race.
Hope that helps. /bing
juantrinidad is offline   Reply With Quote
Old 10-12-2006, 11:26 AM   #3
Default Thanks
Thanks a lot....
I will apply your tips soon...
Tips. Infamouz Nitro On-Road 1 02-09-2007 05:13 PM
Tips thecrow2k R/C Photography 1 05-09-2005 04:07 PM
DIY (Do it Yourself) /\ Tips /\ drive4fun Electric On-Road 11 04-23-2005 07:13 AM
DIY {Do It Yourself} TIPS drive4fun Nitro On-Road 6 04-18-2005 04:45 PM
Tips on what car to buy.. ownage Electric Off-Road 8 11-04-2002 04:21 PM
SEO by vBSEO 3.5.0
