tt-01
is it possible to run a 28t/55t on a tt-01? Will the motor get too hot?
1 Attachment(s)
and yes the motor will get pretty hot.. so it is recommended that you get a heatsink or get a heatsink that has built-in fan on top of it 3racing have that kind of heatsink w/fan and a metal motor mount on your tt-01.. metal motor mount will act like a heatsink coz its metal.. see pix for your gearings.. but i think getting a 28t pinion is a lil' harder.. coz if im not wrong kawada is the one who makes 28t pinion(48pitch) |
ok..thanks...
also, is the standard gearing in a tt-01 48pitch?
tt-01 gears arnt 48p. Go to your LHS and get the proper tt-01 gears.
HTH |
Robinson Racing sells "metric" 48 pitch pinions which work on tamiya cars. I use them on my TT-01, M-03, and M-04. They are stronger and last longer than aluminum.
There will be no problem if you use pinions and spurs that match, so a Robinson Racing "metric" 48 pitch pinion will match a Tamiya 06 module spur and vice versa, but don't try running a mix of 48dp and "metric" 48 pitch because there will be tears before tea, as my granny used to say :cry: :nod: HTH |
so does anyone know were i can get a 28t pinion for my tt-01? anything on ebay?
Tobee used to sell some, but I don't know if they still have any. If your wanting more speed, I would recommend putting another motor in there just to be on the safe side.
and use this http://babelfish.altavista.com to convert the japanese page into english.... look for spur pinion gears under parts list.. hope these helps :nod: :nod: |
