Turbo 4/35 Instruction Question >
Old 09-26-2006, 04:25 AM
Default Turbo 4/35 Instruction Question
Hi Guys,
i have some questions to the 4/35 Turbomatcher, because the instruction manual is a little short
If you cycle the turbomatcher begins to charge first, then it comes a "delay" and after that a "repeak" bevore the discharge begins.
why comes the delay an the repeak ?
Is it programmable that no delay and no repeak is done ?
because the cells become extrem hot after the repeak, and i use a delta voltage of only .01 (the lowest you can choice).
is the "delay" programmable or is it factory set ?
The repeak delta voltage is the same as the delta voltage ? Or does the repeak voltage change with the choice between NimH and NiCD ?
when is the button repeak and discharge (one button ) helpfuel ?
If you use fully charged but cold cells ?
Regards Joe
JohannesM is offline
Old 09-26-2006, 04:42 AM
Joel Lagace's Avatar
In theory you would have your pack peak just before you run so you would not need to repeak. But lets say you are charging the back early and you know apporximatly when u will need it. You could set the repeak for 5,10,15minutes later or what ever. So that you can have the pack ready to go when your expected to run. Rarely am i ever that organized that i was able to use the programed repeak. IF you use it you would normally set the delta down a notch or two and set the time you think u need for delay. On my T35 i always disabled the repeak as i simply would charge then peak when i was a few minutes away from my next run.
Joel Lagace is offline
Old 09-26-2006, 10:11 AM
Hi Joel,
thanks for the answer, but i am not talking about an Turbo 35 Charger.
Here you are totally right an the repeak is settable in minutes for the first time, second and i thing for the third time as well.
I am talking about an Turbomatcher 4/35 (single cell holder).
Here i couldnt find to stop the delay and repeak (one time) function.
knows anybody more
regards joe
Old 09-26-2006, 02:50 PM
RC Professor's Avatar
Trader Rating: 17 (100%+)
Joe, check your Private Messages.
Thanks,
Brian
RC Professor is offline
