Pro 4 on the way!
#76
The Pro 3 wasnt a bad car the only problem is they called what should have been an RS4 3 a PRO 3, when they should have been givin us atleast a Spec V.
I dont think I am gonna get a Pro 4 maybe by the time they get to a Pro5 I will feel enough congidence in their brand again.
#77
Originally posted by TRF414M
Dear Frank,
The reason why some people said PRO 4 is coming out within 6 months because in the RC World Magazine. Hara told them that HPI Japan is planning to release PRO 4 in July or August of this year.
Dear Frank,
-Dave
#78
Please forgive the stupid question guy's but my curiosity is killing me............It appears that the anticipation you guy's are showing for the Pro 4 is tremendous !! I honestly think you HPI folks are showing more enthusiasm than the Tamiya guy's did for the EVO3.I honestly have no experience with HPI......Am I missing something that I really should try?? Do you guy's believe the Pro4 will be THAT different from the EVO ?? Looks very much the same from the pics I've seen. I have always secretly liked the Pro3 chassis layout so I'm looking for somebody to clue me in. Thanks
#79
I do not have any high expectation and I will not be the first one to buy any HPI car. This is the experience that I have from Pro 3. I do not want to waste my limited resource on a car that I know is not going to be fully Options.
Pro 4 is like the rest of the shaft car before. It is not going to be any big surprise. They are testing the car with battery on the left and on the right. Unless they can find a way to solve the limitation on the Spur Gear Selection. Other than that, it will just like the same of the rest in the market.
I am sticking to my Pro 2 in the meantime.
#80
Alot of us on this board are always looking for something new. I myself will buy a Pro4 as soon as it is released, It looks very promising, and HPI has been very good to me in the past. If you feel burned by any car, maybe take some time and get some opinions before you buy it. I had a Pro 3 and it was a decent car for asphalt, not my cup of tea, but HPI quickly adressed it issues.
With the two new releases it appears HPI is really getting into the "Race "Scene.
#82
Bummed about the Pro3 but not the Pro4
I have to say that I thought that the Pro3 would be a little bit better performer than it was... don't get me wrong .it's a great car...it just needs a lot of TLC to get it to work right .. But I think that I'll have a lot more faith in the new design that HPI is doing .. for one it's chaft driven.!! ...and two it night and day from what HPI has done in the past.... I.E. Change from the norm..( even if it's not the most new ground breaking design.... it will still be a fresh idea that is welcomed )...
and best of all you wont have to worry about putting the damn batterys in the car with the HPI or Hotbodies Upper deck!!!!!
-Dave
-Dave
#83
Thanks Spooky and JDM,
Dave...I just e-mailed you before I got on rctech. Need honest opinions on this one. It seems that alot of you had issues with the PRO3 in particular so many of the comments I've read were directed at it. Do you feel the quality and engineering of HPI is on par with Tamiya. To me it seems HPI tends to be more unique in their designs.Rarely have I seen comments where " does that part or that chassis look just like somebody else's". Or from some research I'm doing....Some designs share a good number of parts or you need to use somebody else's parts to make the thing work right. These are from drivers comments. Thoughts??
#84
any manufacturers tried this configuration before ?
#86
R/C Tech Founder
I think a dual-shaft system is too inefficient for an electric powered car. On a nitro car you are ok, because the engine has enough torque that it should not matter.
I think that system could work with a dual belt setup, although given the placement of the motor, I think that weight distribution would be an issue.
#87
on the f201 the axle is not straight and is too high, on this configuration, the axle is totally straight and low as on a tc3, the only problem is that there is 2 more points of contact between the moving parts and the rest of the car
i really don t know if it could work but the car would be perhaps better balanced. (in my opinion)
#88
http://64.70.208.72/speedtechrc/80.html
#89
it is easier with belt trans.cars to have a good weight balance there are a lot of possibilities, if i ve putted the batts front and the motor in the rear there wouldn't have been enough place for the steering servo (except if it is placed in the rear with a very long rod....)
note : the center axle can be solid and one piece style, it just needs some thing to attach the spur gear in the middle.
#90
you would have problems balancing the car with the offset motor and saddle batteries
